File:Cable drive moving apature.PDF
Revision as of 14:57, 30 March 2010 by Rocket scientist (talk | contribs) (Stepper motor driving standard rod with many lengths of cable wrapped around it, the cable secured by a screw in the middle of the cable. When the rod rotates, the gear drive rotates a spreader bar or thread layer. This has two holes that the cable goes t)
Cable_drive_moving_apature.PDF (file size: 9 KB, MIME type: application/pdf)
Stepper motor driving standard rod with many lengths of cable wrapped around it, the cable secured by a screw in the middle of the cable. When the rod rotates, the gear drive rotates a spreader bar or thread layer. This has two holes that the cable goes through. The gear driven short threaded rod causes the spreader bar or threading control to move up and down the rod laying down cable being taken up in such a way that it never over laps, and pulling old cable off the same way. This should be more reliable, albeit more complex, than using threaded rod only for the main shaft and depending on the cable to remain in the threads.
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Dimensions | User | Comment | |
current | 14:57, 30 March 2010 | (9 KB) | Rocket scientist (talk | contribs) | Stepper motor driving standard rod with many lengths of cable wrapped around it, the cable secured by a screw in the middle of the cable. When the rod rotates, the gear drive rotates a spreader bar or thread layer. This has two holes that the cable goes t |
- You cannot overwrite this file.
File usage
There are no pages that link to this file.
