File:Assembly301.zip
Revision as of 12:07, 20 September 2014 by Rapatan (talk | contribs) (Rapatan uploaded a new version of "File:Assembly301.zip")
Assembly301.zip (file size: 970 KB, MIME type: application/zip)
Warning: This file type may contain malicious code.
By executing it, your system may be compromised.
Metalicarap main drawing electron gun and chamber (shielding brick wall aparatus bay and build chamber not shown)
File history
Click on a date/time to view the file as it appeared at that time.
(newest | oldest) View (newer 10 | older 10) (10 | 20 | 50 | 100 | 250 | 500)Date/Time | Dimensions | User | Comment | |
current | 06:07, 25 July 2017 | (970 KB) | Rapatan (talk | contribs) | Modular design implemented through multiple flange connection in gun, Magnetic Lens 1 and Lens 2 are now designed for ease of manufacturer (Part numbers for lenses is coming in next upload) available when .stp file is unziped and opened in FreeCAD. NO... |
05:54, 23 June 2017 | (970 KB) | Rapatan (talk | contribs) | Modular design implemented through multiple flange connection in gun, Magnetic Lens 1 and Lens 2 are now designed for ease of manufacturer (Part numbers for lenses is coming in next upload) available when .stp file is unziped and opened in FreeCAD. NO... | |
11:35, 8 September 2016 | (1,021 KB) | Rapatan (talk | contribs) | Minor changes to the bulb socket | |
06:26, 4 June 2016 | (1,013 KB) | Rapatan (talk | contribs) | Manor improvements, part numbers/ version number/ description/ material information. available when .stp file is unziped and opened in FreeCAD. NOW READY FOR BUILDING - using standard part for cross c-0600-450 Lesker bottom flange removed 50mm down f... | |
04:47, 21 May 2016 | (1,013 KB) | Rapatan (talk | contribs) | Manor improvements, part numbers/ version number/ description/ material information. available when .stp file is unziped and opened in FreeCAD. NOW READY FOR BUILDING - using standard part for cross c-0600-450 Lesker bottom flange removed 50mm down f... | |
09:22, 11 June 2015 | (959 KB) | Rapatan (talk | contribs) | NOW READY FOR BUILDING - using standard part for cross c-0600-450 Lesker bottom flange removed 50mm down from bottom of cross, buildplatform and brick lined technical apparatus rack not included. part number with out leading zeros and with out version ... | |
10:25, 31 May 2015 | (959 KB) | Rapatan (talk | contribs) | NOW READY FOR BUILDING - using standard part for cross c-0600-450 Lesker bottom flange removed 50mm down from bottom of cross, buildplatform and brick lined technical apparatus rack not included. part number with out leading zeros and with out version ... | |
08:02, 21 February 2015 | (972 KB) | Rapatan (talk | contribs) | NOW READY FOR BUILDING - using standard part for cross c-0600-450 Lesker bottom flange removed 50mm down from bottom of cross, buildplatform and brick lined technical apparatus rack not included. | |
10:29, 25 January 2015 | (968 KB) | Rapatan (talk | contribs) | NOW READY FOR BUILDING - using standard part for cross c-0600-450 Lesker bottom flange removed 50mm down from bottom of cross, buildplatform and brick lined technical apparatus rack not included. | |
13:10, 10 January 2015 | (968 KB) | Rapatan (talk | contribs) | NOW READY FOR BUILDING - using standard part for cross c-0600-450 Lesker bottom flange removed buildplatform and brick lined technical apparatus rack not included, |
- You cannot overwrite this file.
File usage
The following page links to this file:
