File:Adaptacion Husillos.zip
Revision as of 10:08, 15 January 2015 by Hari Seldon (talk | contribs)
Adaptacion_Husillos.zip (file size: 685 KB, MIME type: application/zip)
Warning: This file type may contain malicious code.
By executing it, your system may be compromised.
Adaptación para usar husillos de 10mm de diámetro en la P3Steel
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Dimensions | User | Comment | |
current | 20:19, 15 July 2014 | (685 KB) | AnavarroCW (talk | contribs) | Se ha ajustado para dejar más espacio entre el eje X y el marco, ya que tal como estaba antes, quedaba demasiado justo. Se pierde algo (entre 0.5 y 1cm) en el eje Y, pero creo que compensa. |
15:42, 28 November 2013 | (124 KB) | AnavarroCW (talk | contribs) | Adaptación para usar husillos de 10mm de diámetro en la P3Steel |
- You cannot overwrite this file.
File usage
The following 3 pages link to this file:
