File:Absprusa - installing the optional guide bearing.jpg
Revision as of 17:01, 31 May 2012 by Roland (talk | contribs) (There is no M4 16mm bolt in the kit to install the optional 624zz guide bearing, and it would be too short anyway. Just take the last 20mm bolt and insert it from the outside and secure it with the M4 nyloc nut from the inside :-))
Original file(1,229 × 922 pixels, file size: 121 KB, MIME type: image/jpeg)
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeThumbnailDimensionsUserComment
current18:25, 31 May 2012Thumbnail for version as of 18:25, 31 May 20121,229 × 922 (121 KB)Roland (talk | contribs)
17:01, 31 May 2012Thumbnail for version as of 17:01, 31 May 20121,229 × 922 (141 KB)Roland (talk | contribs) There is no M4 16mm bolt in the kit to install the optional 624zz guide bearing, and it would be too short anyway. Just take the last 20mm bolt and insert it from the outside and secure it with the M4 nyloc nut from the inside :-)
  • You cannot overwrite this file.
There are no pages that link to this file.
Metadata
