File:2014 Weiss Closed-Loop Control of a 3D Printer Gantry Fig 12.png
Revision as of 03:12, 11 December 2015 by 100ideas (talk | contribs) ("Figure 12. High speed change performance. (a) Open-loop control at normal speed change (15 mm/s max) and high speed change (300 mm/s max). (b) PI control performance under normal and high speed change." https://digital.lib.washington.edu/researchwork...)
Original file(763 × 1,043 pixels, file size: 206 KB, MIME type: image/png)
https://digital.lib.washington.edu/researchworks/bitstream/handle/1773/26048/Weiss_washington_0250O_13644.pdf
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeThumbnailDimensionsUserComment
current03:12, 11 December 2015Thumbnail for version as of 03:12, 11 December 2015763 × 1,043 (206 KB)100ideas (talk | contribs)"Figure 12. High speed change performance. (a) Open-loop control at normal speed change (15 mm/s max) and high speed change (300 mm/s max). (b) PI control performance under normal and high speed change." https://digital.lib.washington.edu/researchwork...
  • You cannot overwrite this file.
The following page links to this file:
Metadata
