File:10-11-12 ROSTOCK MAX RELEASE BY PARTDADDY SEEMECNC.zip
10-11-12_ROSTOCK_MAX_RELEASE_BY_PARTDADDY_SEEMECNC.zip (file size: 4.41 MB, MIME type: application/zip)
Warning: This file type may contain malicious code.
By executing it, your system may be compromised.
This file is every part of the machine that requires manufacturing. All parts (even laser cut) are in STL format. For 1/4" thick (6mm thick) sheet stock.
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Dimensions | User | Comment | |
current | 14:17, 11 October 2012 | (4.41 MB) | Partdaddy (talk | contribs) | This file is every part of the machine that requires manufacturing. All parts (even laser cut) are in STL format. For 1/4" thick (6mm thick) sheet stock. |
- You cannot overwrite this file.
File usage
The following page links to this file:
