Filament Spindle
Revision as of 11:04, 28 July 2010 by Tbuser (talk | contribs) (Planned Features)
Filament Spindle
Release status: concept
[[image:|center|190px]]
Filament Spindle
GPL
Introduction
A printable built-in filament management solution. Hopefully bringing an end to tangled messes and bizarre hanging contraptions!
Inspiration
Building on the work of these other designs.
Filament Spindle MK1 by makerbot
Printable horizontal filament spool.jpg Printable horizontal filament spool render.jpg
Printable Horizontal Filament Spool by Spacexula
The end result will look similar to the base of this Mini-Mendel rendering.
Planned Features
  • can either be attached to the Mendel frame, sit under it, or be stacked beside it
  • stackable for multiple spools and/or multiple extruder configurations
  • can either feed directly into a normal extruder or provide a mounting spot for a bowden fed extruder motor
  • takes up less space and more stable than the similar in concept Mendel Feed Spool
  • all cad files created using OpenSCAD
Parts
Printed Parts
So far the following parts have been optimized and converted to OpenSCAD...
Requires mendel.inc and mendel.conf from the Parameterized Mendel project.
Printed Image CAD Image OpenSCAD STL Description
File:Spindle.scad Common modules included by other scripts
File:Spindle-tube-fitting.scad Defines shape of the tube fitting used by tube holder
Spindle-hub 1off print.jpg Spindle-hub 1off.png File:Spindle-hub 1off.scad File:Spindle-hub 1off.stl Central hub with bearing that spool turns on
Spindle-tube-holder 1off print.jpg Spindle-tube-holder 1off.png File:Spindle-tube-holder 1off.scad File:Spindle-tube-holder 1off.stl Uses an embedded tube fitting (same as MakerBot's) along with HDPE tube to feed filament through
200px Spindle-bearing-bracket 2off.png File:Spindle-bearing-bracket 2off.scad File:Spindle-bearing-bracket 2off.stl TODO: Holds up half of the bearing rollers that the spool spins on
200px Spindle-support-bearing-bracket 4off.png File:Spindle-support-bearing-bracket 4off.scad File:Spindle-support-bearing-bracket 4off.stl TODO: Holds up half of the bearing rollers that the spool spins on as well as 2 cross bearing rods top and bottom
200px 200px File:Spindle-corner-bracket-left 4off.scad File:Spindle-corner-bracket-left 4off.stl TODO: left corners
200px 200px File:Spindle-corner-bracket-right 4off.scad File:Spindle-corner-bracket-right 4off.stl TODO: right corners
Vitamins
McMaster # Price Each Quantity Total Price Description
98861A080 $2.27 7 $15.89 Metric Class 4.6 Plain Steel Threaded Rod M8 Size, 1 Meter Length, 1.25 mm Pitch (not sure if this is the right number of rods yet)
2381T15 $10.47 1 $10.47 One-Piece Polystyrene Spool 3-1/2" Core Dia X 5" L Core X 10-1/2" Flange Dia (probably better to make your own spool, this is expensive)
50375K41 $0.14 25 $3.50 about 900mm HDPE Tubing - 1/4" OD, 1/8" ID (25' is smallest size for sale, maybe PTFE tube would be better?)
5225K712 $2.85 1 $2.85 Brass Push-to-Connect Tube Fitting Adapter for 1/4" Tube OD X 1/8" NPTF Male Pipe
91862A101 $1.86 1 $1.86 1/8"-27 NPT Nut (for mounting tube fitting)
90592A022 $4.29 2 $8.58 M8 nuts (probably need like 128)
93475A270 $7.00 2 $14.00 M8 washers (probably need like 128)
vxb.com is cheaper $0.59 5 $2.95 608ZZ Bearing 8x22x7 Shielded
$60.10 TOTAL
Assembly
Coming Soon...
TODO
  • order vitamins vitamins arrived and seem to be correct
  • make some modifications to Printable Horizontal Filament Spool models (might need diagonal reinforcement?)
  • figure out proper dimensions and most efficient way to cut 1m rods
  • figure out a logical way to attach to bottom of Mendel frame
