Extruder Nozzle Variations
Revision as of 13:06, 27 September 2010 by GilesBathgate (talk | contribs) (Split Heater Block)
Example Development
Release status: unknown
documenting a generic tool/artpiece
Split Heater Block
I found that glue can be a bit sticky to work with. You have to use special glue with high thermal rating which can also be hard to find. So I decided to come up with a glue-less alternative for the heater block.
Split Heater Block
Its simply an aluminium block, with a split (the thickness of a saw blade) cut down the middle. The hole that accepts the nozzle is then taped to M6 in the bottom half, and drilled out to a clearance hole in the top half. As you clamp the heater block onto the nozzle it closes the gap slightly and grips the power resistor nice and snug.
  • Advantages
    • No need for glue
    • Looks like some kind of woodblock instrument
  • Disadvantages
    • Less material to conduct heat
Its quite a delicate thing to make but can easily be made using the following technique. Start with a length of 3/4" square aluminium bar. Use the whole length of bar to your advantage and clamp it so that you can drill the hole in the right place at one end. Once the hole is drilled you can cut the split 4.5mm from the end of the bar, straight down the centre of the hole. I used a mitre saw to get my cut nice and square, but I am sure you could also do this with a junior hack saw, so long as you mark a line to follow. You don't want to make the split all the way through, so stop cutting a few mm before you cut all the way through. Finally cut the 9mm block of the end of the bar. The reason its easier to do it this way round is that its a lot harder to hold once you have cut it into a little block.
Rounded Support Block
I wanted to make a cheaper version of the support block so I decided to publish this design that uses PEEK rod instead of PEEK sheet. This is an alternative to crowd sourcing.
  • Advantages
    • Cheaper - more than ten times cheaper if you buy PEEK rod at £11.87 instead of PEEK sheet at £158.00
    • Aesthetically pleasing - Although this is a matter of taste.
  • Disadvantages
    • Possibly harder to cut.
To make the rounded support block buy some 16mm dia PEEK rod. Cut a 42mm length of rod. Now cut two flats down the length of the rod. This can probably be done quite easily in a band saw, but I did it using a mitre saw and the following technique. Drill a 16mm hole into a scrap block of wood. Tap the PEEK rod into the hole in the wood. The wooden block acts as a destructible work piece clamp, now make a cut starting from the end of the rod, all the down and through the PEEK and also through the wood. Then repeat the process to get the other flat. The other holes are drilled in the same was as the original PEEK support block.
No Lathe - Variation
No lathe - Variation
After seeing Adrian's Geared extruder nozzle I immediately liked it, but realized that it would be even harder to make than older designs. Reprap is supposed to be make-able in your garage, I don't even have a garage. So I offer this design as a compromise, that you can literally make in your front living room. Its similar in essence to Adrian's design. I admit its not completely lathe free since you still have to buy a nozzle. These however can be readily bought from from your fellow developers in places like the RepRap Marketplace, Makerbots, RepRapSource, and RepRapStores.
  • Advantages
    • Easier to make if you don't have access to a lathe.
  • Disadvantages
    • Still relies on some bought machined parts.
    • PTFE buts up to barrel instead of being inside it.
To make this you will need to buy some 10mm PTFE and put a thread on it. Next you drill and tap some 16mm dia PTFE with an M10 internal thread. Screw the 10mm PTFE into the 16mm PTFE and you will have the completed PTFE insulator part shown bottom left. To make the middle part you use a piece of 16mm dia alu round bar, drill a 5mm hole all the way through the centre, then drill an 8.5mm hole to 8mm deep into one end. Tap the 5mm hole to M8 and 8.5mm hole to M10. Use the instructions for a rounded peek support block above to make the support block. The central hole in the block can be M6 threaded as shown if you prefer. The completed assembly is shown bottom right.
