Ecksbot
Description | ecksbot sturdier and sleeker derivative of the Prusa 2.
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Introduction
The ecksbot design is a sturdier and sleeker derivative of the Prusa 2 built on EckerTech innovations and putting a little more Sells Mendel back into the mix, making it a true and evolutionary RepRap.
We do not claim this as our own new design but rather another small step in the evolution of the RepRap hobby printer. It is designed around the concepts and efforts of the RepRap core team and should be considered as an extension of the project.
We would like to thank the RepRap core team for inspiring not just us but the entire RepRap community to design, redesign, innovate and think outside the box. Without the core team none of this would be possible.
Keeping with RepRap tradition the ecksbot is released on the GPL license making this a true RepRap 3D printer.
Video Clip
<videoflash>b88uoyQ6-W8</videoflash>
Development
The development of the ecksbot is hosted on github: http://github.com/eckertech/ecksbot.
You can follow the changes on Changelog.
You can sign up for github for free and fork the project to begin working on it.
You can also join our forum @ http://forum.eckertech.com for updates, a complete construction manual, Q&A and general topic discussion.
Bill of Materials
Printed Parts
Hardware
Quantity | Description | Type | Comments |
80 | M8 nut | Fastener | |
76 | M8 washer | Fastener | |
3 | M4×40mm bolts | Fastener | |
1 | M4×40mm fully threaded bolt | Fastener | eckstruder idler bolt |
9 | M4x20mm bolts | Fastener | |
4 | M4x16mm bolts | Fastener | |
19 | M4 nuts | Fastener | |
16 | M4 washers | Fastener | |
12 | M3×20mm bolts | Fastener | |
18 | M3x10mm bolts | Fastener | stepper motor bolts |
12 | M3 nuts | Fastener | |
32 | M3 washers | Fastener | |
1 | Hobbed Bolt | Fastener | |
1 | M8×450mm | Threaded rod | |
3 | M8×435mm | Threaded rod | top / bottom |
6 | M8×370mm | Threaded rod | 3 per side (triangle frames) |
4 | M8×290mm | Threaded rod | front / rear |
2 | M8×210mm | Threaded rod | Z-leadscrew |
2 | 8mm×425mm | Smooth rod | X-bar |
2 | 8mm×406mm | Smooth rod | Y-bar |
2 | 8mm×330mm | Smooth rod | Z-bar |
2 | 8mm×28mm | Smooth rod or Threaded rod | eckstruder Idler |
2 | 1,000mm×5mm T5 pitch timing belt | Belt | X & Y axis |
11 | LM8UU linear motion bearings | Bearings | |
6 | 608 bearings | Bearings | |
5 | NEMA 17 bipolar stepper motor | Motor | We recommend using stepper motors with at least a Maximum Holding Torque of 60 oz-in |
34 | Zip Ties | Consumables | |
3 | Microswitches | End Stop | |
2 | springs | Spring | one each, for the X-Idler and X-Motor mount |
2 | Rubber bushings | bushings | rubber bushings for attaching the Z stepper motors to the couplers |
1 | Rubber dust guard | Consumables | rubber dust guard for the filament |
1 | eckstruder rubber grommet | Consumables | Rubber grommet or spring for eckstruder |
1 | extruder fan | Fan |
