Echorap
Revision as of 11:10, 17 October 2012 by Stephaner (talk | contribs) (Created page with '<a href="http://www.roboticsequencing.com/wp-content/uploads/2012/10/DSC_0005.jpg"><img src="http://www.roboticsequencing.com/wp-content/uploads/2012/10/DSC_0005-687x1024.jpg" al…')
<a href="http://www.roboticsequencing.com/wp-content/uploads/2012/10/DSC_0005.jpg"><img src="http://www.roboticsequencing.com/wp-content/uploads/2012/10/DSC_0005-687x1024.jpg" alt="" title="EchoRap " width="620" height="924" class="alignright size-large wp-image-293" /></a>
The EchoRap is a simple and robust RepRap designed by Robotic Sequencing in Montreal’s first and only Fab Lab, ÉchoFab. It’s a low cost and simplified version of the original RepRap using tubes instead of threaded rods for a different geometry. The design is licensed under <a href="http://creativecommons.org/licenses/by-nc/3.0/">Creative Commons Non-Commercial</a>, so if you have acces to a 3D printer, you can print one for yourself or to give to a friend. Files to print parts are available on Thingiverse.
The design allows builders to build it as a RepRap or a RepStrap. All parts can be printed or cut. Assembly of the structure is very easy: tubes and simple coupling. The X Y Z axes can be enlarged using longer tubes and rods. Current table size allows the use of standard Mendel or Prusa heated beds. Gen7 Electronics, PrintrBoard rev D has been tested and works well. Other RepRap electronics can also be used. All the sofware is Open-Source.
SPECIFICATIONS
Overall Dimensions: 510mm x 585mm x 540mm (20.1in x 23.1in x 21.26in) Weight: 8.18kg (18lbs) Usable Print Area: 220mm x 220mm x 200mm (7.9in x 7.9in x 7.87in)
VIDEOS
The EchoRap is action: <object width="640" height="480"><param name="movie" value="http://www.youtube.com/v/3Qng64k36mw?version=3&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/3Qng64k36mw?version=3&hl=en_US" type="application/x-shockwave-flash" width="640" height="480" allowscriptaccess="always" allowfullscreen="true"></embed></object>
ORDER
Choose your color: White, Red, Orange, Blue, Green. Silver (a little extra) Complete kit or Mechanical only kit will be available soon.
If you like to be advised or want to be a distributor, send a email to [email protected]
COMPLETE KIT CONTENT Items / Quantity
Structure Y axis Tube 1.125" 14" / 2 X axis Tube 1.125" 15" / 2 Z axis Tube 1.125" 15" / 2 Top Tube Handle Bar 1.125" 23" / 1 Tube Joint / 18
EchoRap Specific Parts P1Y NEMA 17 Mount / 1 P2Y Bearing Holder / 1 P3Z NEMA 17 Mount / 2 P4Z Top Mount / 2 P5X NEMA 17 Mount / 1 P6X Right Mount / 1 P7 Extruder Mount / 1 P8 Table / 1 P9 LM12UU Holder / 8 P10 Adaptor 1.125" to 12mmx0.5" long / 12
Moving Parts 12 mm Rod 13" / 4 LM12UU Linear Bearing 12x21x30mm / 8 608ZZ Bearing (to build structure, extruder not counted) / 2 5/16 18TPI Threaded Rod 13" / 2 Pulley GT2 36 teeth, 6mm width / 2 Belt GT2 497 teeth, 6mm width / 2
Hardware M3 X 12mm Socket Bolt (motor mount) / 20 M3 X 25mm Socket Bolt (P1, P2, P3, P4 attach) / 6 M3 Hex Nut / 6 Multipurpose Miniature Tie 102mm / 100 5/16 Nut / 4 M8 X 30mm Bolt / 2 M8 Lock Nut / 2 M8 Washer / 4 M8 Large Washer / 4 L-Shaped Metal Mount 50mmx50mmx12mm / 2
Electronics NEMA 17 Stepper Motor 62 oz-in / 5 PrintrBoard rev D / 1 Extruder Wade / 1 Hotend J-Head / 1 PCB Heated Bed MK1 or more / 1 ATX Power Supply / 1 Motors Cables / 5 Other Cables / 7
DOCUMENTATION AND SOFTWARE <a href="http://www.thingiverse.com/thing:32557/">Files to make one on Thingiverse</a> <a href="http://www.roboticsequencing.com/products-2/echorap/">Pre-order</a> <a href="http://www.echofab.org/wiki/index.php/%C3%89choRap">échoRap Wiki</a> (in french) <a href="https://github.com/roboticseq/RSEchoRapSprinterForPrintrBoardRevD">Firmware for PrintrBoard Rev D</a> on GitHub. <a href="https://github.com/roboticseq/RSEchoRapMarlinForGen7v131">Firmware for RepRap Gen7 Electronic v1.3.1</a> on GitHub.
