EMAKER Huxley
EMAKER Huxley
Release status: experimental
Description | |
License | unknown
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
This is a redesigned Huxley inspired by the Prusa simplified Mendel. The information on this wiki page is not yet complete, so do not attempt to build this machine. I will keep updating this page over the next few days until there is enough information on here for a complete build of the eMAKER Huxley design.
Brief specification
- 140x140x110mm build vollume
- Heated build surface
- Bowden fed extruder for 1.75mm filament
History
Bill of Materials
Printed Parts
Quantity | Description | Type | Comments | Diagram |
2 | coupling | RP | ||
1 | x-idler-bracket | RP | ||
1 | x-motor-bracket | RP | ||
1 | x-carriage | RP | ||
1 | nozzle-mount | RP | ||
1 | idler-cover | RP | ||
1 | y-motor-bracket | RP | ||
1 | y-idler-bracket | RP | ||
2 | frame-vertex | RP | ||
4 | frame-vertex-foot | RP | ||
2 | z-motor-mount | RP | ||
8 | bar-clamp | RP | ||
2 | belt-nut-trap | RP | ||
1 | z-endstop-holder | RP | ||
1 | spring-anchor-single | RP | ||
1 | spring-anchor-double | RP | ||
4 | bearing-holder | RP | ||
4 | M6-extruder-block | RP | 80px | |
4 | idler | RP | 80px | |
4 | small-gear | RP | 80px | |
4 | large-gear | RP | 80px |
Non-Printed Parts ("vitamins")
2x Nema 14 bipolar stepper motor, 14Ncm 2x Nema 14 bipolar stepper motor, 6Ncm 50x Small cable binder/ziptie Misc. 6x 6mm Linear bearings 4x 6mm Igus clip bearings 1x 140x140x5mm milled Aluminium build surface 2x T2.5 16 tooth Aluminium timing pulleys 2x T2.5 timing belts 2x 623 bearings 2x 626 bearings 1x Electronics + endstops. This can be RAMPS,Sanguinololu, Generation_7_Electronics, or anything else compatible.
(The eMAKER Huxley uses the 4 drivers in the standard Mendel electronics package to drive 5 motors by using "two steppers wired in parallel to one driver"[1]).
Printing the Parts
Buy the printed parts
Coming soon to eMAKERshop
