EI3
HE3D-EI3
Description | Based on prusa i3.
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | none
External Link |
Assembly instructions
- Assembling hotend carriage 01-A-9
- Mounting motor to hotend carriage 02-B-6-1
- Left Z-carriage 03-B-7
- Right z-carriage with motor 04-B-5
- Bottom board with Y-carriage 05-B-4
- Bottom crose frame 06-B-6-3
- Bottom frame and side frame 07-B-6-2
- Mount a wheel to front of bottom frame 08-B-2
- Mount the motor to bottom frame 09-B-3
- Horizontal frame(X Axis) 10
- Axle sleeve of z-axis 11-B-4-1
- Top frame ,lead screw of z-axis, z-motor 12-B-4-2
- Extruder motor and clip 13-B-7-1
- Mount (hotend , bottom board, x-belt, y-belt) to frame 14
- Control panel 15-A-6
- Main board heating bed , limited switch 16-A-10
Circuit diagram
Product Specifications
Parameters | Description |
Structure | Aluminum profiles(black) |
Frame | Metal |
Print Size(X Y Z) | 200×200×200mm/200*280*200mm |
Layer Resolution | 100 Microns |
Print Precision | 0.1-0.4mm |
Print Head | Single/Dual/Triple |
XY Axis Positioning Accuracy | 0.012mm |
Z Axis Positioning Accuracy | 0.004mm |
LCD Screen | YES |
Nozzle Temperature | 210℃(MAX 260℃) |
Power Supply | DC 12v/250W |
Connection | SD Card or USB |
OS | Windows XP,Windows Vista,Windows 7,MAC OX |
Software | Repetier-Host,Cura,Slic3r |
Material Type | PLA,ABS,HIPS,Wood,PVA,Nylon,Flexiable PLA,Copper fill (metal) |
Material Specifications | 1.75mm |
Exreuder | Full Metal The Newest Design |
Nozzle Size | 0.2 0.3 0.4 0.5mm |
Machine Size | 430×440×400mm |
Full Kits Packing List
A Floor | Units |
2040 Aiuminum Extrusion 420mm (2040型材 420mm) | 2 |
2040 Aiuminum Extrusion 400mm (2040型材 400mm) | 1 |
2020 Aiuminum Extrusion 400mm (2020型材 400mm) | 1 |
2020 Aiuminum Extrusion 380mm (2020型材 380mm) | 1 |
Threaded Rods 380m (丝杆 380mm) | 1 |
Aluminum Wires Holder (型材藏线管) | 3 |
2040 Aluminum Extrusion 150mm (2040型材 150mm) | 2 |
Acrylic For LCD Display (亚克力 -显示屏) | 2 |
2004 LCD Display | 1 |
screw Kits A-6 (螺丝包 -A6) | 1 |
Acrylic For L Alunimun Connector (压克力 - L型) | 2 |
screw Kits A-7 (螺丝包 -A7) | 1 |
Acrylic For End Stop (亚克力 -限位开关) | 2 |
screw Kits A-8 (螺丝包 -A8) | 1 |
X Carriage -Holde (亚克力 -X轴马车) | 1 |
screw Kits A-9 | 1 |
B Floor | Units |
Step Motors (电机) | 4 |
Acrylic For Y Axis Front (亚克力 -Y轴前) | 2 |
Kits - B2 (螺丝包 -B2) | 1 |
Acrylic For Y Axis Black (亚克力 -Y轴后) | 2 |
Kits - B3 (螺丝包 -B3) | 1 |
Acylic For Heat bed Holder (亚克力 -热床底座) | 1 |
Kits - B4 (螺丝包 -B4) | 1 |
Acrylic For copper Holder (亚克力 -铜螺母) | 1 |
Kits - B4 -1 (螺丝包 -B4-1) | 1 |
Acrylic For Z Aixs Step Motor (亚克力 -Z轴电机座) | 3 |
Kits - B4 -2 (螺丝包 -B4-2) | 2 |
Belt (皮带) | 2 |
Wires Protection (绕线管) | 1 |
Kits - B5 (螺丝包 -B5) | 1 |
E3d & Cool Fan (E3D) | 1 |
Gift Kits (礼物套件) | 1 |
L aluminum Connector (L型材连接器) | 1 |
Tools (小工具) | 1 |
Acylic For Z Axis Left Holder (亚克力 -Z轴左) | 1 |
Kits - B7 (螺丝包 -B7) | 1 |
Feeder (送丝机 -B7 -1) | 1 |
Power Supply (电源) | 1 |
C Floor | Units |
End Stop (限位开关) | 3 |
Step Motors Wires (电机线) | 4 |
Wires of power supply (电源线) | 1 |
Plug (插头) | 1 |
USB Cable (USB线) | 1 |
USB Cable (USB线)) | 1 |
Heat Bed (Mk3热床) | 1 |
PTFE Tube (四氟管) | 1 |
Filaments (耗材) | 2 |
Help and Support
- You can download the firmware from here:[1]
- More technical support: [2]
- This printer have no any printed part, but if you want to print some parts by yourself,
- please download the stl file from here:[3] [4][5][6][7]
Photos
Videos
Unboxing Video - HE3D EI3 3D Printer: 1 - EI3 3D Printer <videoflash>Nu__clyW1vs<ideoflash>
