EI3
Revision as of 04:48, 25 October 2016 by Lou (talk | contribs)
HE3D-EI3
Based on prusa i3.
none
Assembly instructions
  1. Assembling hotend carriage 01-A-9
  2. Mounting motor to hotend carriage 02-B-6-1
  3. Left Z-carriage 03-B-7
  4. Right z-carriage with motor 04-B-5
  5. Bottom board with Y-carriage 05-B-4
  6. Bottom crose frame 06-B-6-3
  7. Bottom frame and side frame 07-B-6-2
  8. Mount a wheel to front of bottom frame 08-B-2
  9. Mount the motor to bottom frame 09-B-3
  10. Horizontal frame(X Axis) 10
  11. Axle sleeve of z-axis 11-B-4-1
  12. Top frame ,lead screw of z-axis, z-motor 12-B-4-2
  13. Extruder motor and clip 13-B-7-1
  14. Mount (hotend , bottom board, x-belt, y-belt) to frame 14
  15. Control panel 15-A-6
  16. Main board heating bed , limited switch 16-A-10
Product Specifications
Parameters Description
Structure Aluminum profiles(black)
Frame Metal
Print Size(X Y Z) 200×200×200mm/200*280*200mm
Layer Resolution 100 Microns
Print Precision 0.1-0.4mm
Print Head Single/Dual/Triple
XY Axis Positioning Accuracy 0.012mm
Z Axis Positioning Accuracy 0.004mm
LCD Screen YES
Nozzle Temperature 210℃(MAX 260℃)
Power Supply DC 12v/250W
Connection SD Card or USB
OS Windows XP,Windows Vista,Windows 7,MAC OX
Software Repetier-Host,Cura,Slic3r
Material Type PLA,ABS,HIPS,Wood,PVA,Nylon,Flexiable PLA,Copper fill (metal)
Material Specifications 1.75mm
Exreuder Full Metal The Newest Design
Nozzle Size 0.2 0.3 0.4 0.5mm
Machine Size 430×440×400mm
Help and Support
  • You can download the firmware from here:[1]
  • More technical support: [2]
  • This printer have no any printed part, but if you want to print some parts by yourself,
  • please download the stl file from here:[3] [4][5][6]
Photos
Videos
Unboxing Video - HE3D EI3 3D Printer: 1 - EI3 3D Printer <videoflash>Nu__clyW1vs<ideoflash>
