EI3
HE3D-EI3
Description | Based on prusa i3.
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | none
External Link |
Assembly instructions
- Assembling hotend carriage 01-A-9
- Mounting motor to hotend carriage 02-B-6-1
- Left Z-carriage 03-B-7
- Right z-carriage with motor 04-B-5
- Bottom board with Y-carriage 05-B-4
- Bottom crose frame 06-B-6-3
- Bottom frame and side frame 07-B-6-2
- Mount a wheel to front of bottom frame 08-B-2
- Mount the motor to bottom frame 09-B-3
- Horizontal frame(X Axis) 10
- Axle sleeve of z-axis 11-B-4-1
- Top frame ,lead screw of z-axis, z-motor 12-B-4-2
- Extruder motor and clip 13-B-7-1
- Mount (hotend , bottom board, x-belt, y-belt) to frame 14
- Control panel 15-A-6
- Main board heating bed , limited switch 16-A-10
Product Specifications
Parameters | Description |
Structure | Aluminum profiles(black) |
Frame | Metal |
Print Size(X Y Z) | 200×200×200mm/200*280*200mm |
Layer Resolution | 100 Microns |
Print Precision | 0.1-0.4mm |
Print Head | Single/Dual/Triple |
XY Axis Positioning Accuracy | 0.012mm |
Z Axis Positioning Accuracy | 0.004mm |
LCD Screen | YES |
Nozzle Temperature | 210℃(MAX 260℃) |
Power Supply | DC 12v/250W |
Connection | SD Card or USB |
OS | Windows XP,Windows Vista,Windows 7,MAC OX |
Software | Repetier-Host,Cura,Slic3r |
Material Type | PLA,ABS,HIPS,Wood,PVA,Nylon,Flexiable PLA,Copper fill (metal) |
Material Specifications | 1.75mm |
Exreuder | Full Metal The Newest Design |
Nozzle Size | 0.2 0.3 0.4 0.5mm |
Machine Size | 430×440×400mm |
Help and Support
- You can download the firmware from here:[1]
- More technical support: [2]
- This printer have no any printed part, but if you want print some parts by yourself, please download the stl file from here:
http://www.thingiverse.com/thing:1778934 http://www.thingiverse.com/thing:1793304 http://www.thingiverse.com/thing:1783145 http://www.thingiverse.com/thing:1778783
