E1x
Description | A t-slot 3d printer by tjb1
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
E1x is a printer designed by tjb1.
Parts
The files for the printed parts can be found here[1].
BOM
Please make sure that this table is up to date with the google docs BOM found here[2] before you purchase/cut your materials!Note: VXB and McMaster smooth rod will need to be cut to length, Misumi links are for cut materials.
Quantity | Size | Description | Part Number | Misumi | McMaster | VXB | Fastenal |
4 | 3mm x 10mm x 4mm | Flanged Bearing | F623 or F623ZZ | [3] | |||
4 | 30mm x 30mm x 20mm | Corner Bracket | HBLFSN5 | [4] | |||
2 | 370mm x 8mm | X Axis Smooth Rod | [5] | [6] | [7] | ||
2 | 350mm x 8mm | Y Axis Smooth Rod | [8] | [9] | [10] | ||
2 | 320mm x 8mm | Z Axis Smooth Rod | [11] | [12] | [13] | ||
2 | 20mm x 20mm x 368mm | 2020 Extrusion (Z) | [14] | ||||
2 | 20mm x 20mm x 330mm | 2020 Extrusion (Y) | [15] | ||||
3 | 20mm x 20mm x 330mm | 2020 Extrusion (X) | [16] | ||||
2 | M5 x .8 - 305mm | Threaded Rod | [17] | [18] | |||
2 | M3x20 | Socket Cap Screw | |||||
12 | M3x6 | Socket Cap Screw | |||||
8 | M3x12 | Socket Cap Screw | |||||
3 | M3x16 | Socket Cap Screw | |||||
50 | M5 | TSlot Nuts | |||||
50 | M5x8 | Screws for Tslot nuts | |||||
3 | SPDT Micro Switches | Small switches similar to [19] |
Note: If subsituting different-length rods (such as if converting an i3), make sure to apply the difference between the desired smooth rod length and the BOM to the extrusions.
Assembly
Preparation:
1) Make sure you have everything in the BOM. You should have 2 Z extrusions, 2 Y and 3 X. In the BOM, the X and Y are the same length, the Z extrusions are longer.
Y-Axis:
Needed components:
- 2 2020 extrusions for Y, 2 2020 extrusions, sized for X
- 22 T-slot nuts (or analog)
- 4 corner brackets
- 1 Y motor mount
- 1 NEMA 17 Stepper motor.
- 4 Y smooth rod mount
- 1 Y idler block
- 2 623zz (preferably FL623zz) roller bearings.
- 1 GT2 belt
- Y-carriage plate and needed linear bearings/bushings
- 1 Y belt gripper
- 4 Printer Support
- 1 Micro Switch
- Take the 2 Y extrusions, and slot 2 nuts into one side and 3 nuts into the opposite side. Do this for both and put them down.
- Take the 2 X extrusions, and slot 5 nuts into the same side. Loosely install a corner bracket on both ends of each extrusion.
- Slot 2 nuts into one of the adjacent faces (this side will be on the bottom).
- If there is anything else you are planning to install (such as a power supply mount or electronics) on the Y extrusions, install nuts for it now.
- Join the X and Y extrusions with the corner brackets. The Y extrusions should have 2 nuts facing "inward" and 3 nuts facing "outward". The end of the Y extrusions should be flush against the surface of the X extrusions.
- Assemble the Y carriage. For a normal Prusa i3 carriage, this involves installing all 3 linear bearings to the plate and the belt gripper.
- Slide one Y smooth rod mount onto each Y smooth rod (normally the 350mm long rods).
- Place the carriage onto the Y smooth rods.
- Place the other two smooth rod mounts onto the Y smooth rods.
- Center the bed and use the previously-placed t-slot nuts to fasten the bed to the X extrusions.
- Flip the entire piece upside down.
- With a M3x20 screw, install the 623 bearings into the Y idler. If using FL623 bearings, the rim should be on the outside part (so that there is a place for the belt to sit).
- Use 2 M3x12 screws to fasten the endstop switch to the Y motor block. It may be necessary to drill out the holes in the switch and the Y motor block; do so carefully with a 7/64 SAE or 3mm metric drill bit. If you use a 3mm metric drill bit, use 2 M3 nuts to secure the Y endstop.
- With 4 M3x6 screws, install the Y motor to the Y motor block. The motor should be orientated such that the motor is flush against the "bottom" of the part.
- Loosely install the GT2 pulley on the Y motor shaft, grub-screws towards the motor.
- Install the Y motor block and Y idler loosely, then line them up with the gripper and tighten into place. The extension on the gripper should contact the endstop switch.
- Install the GT2 belt in half of the gripper, then thread it through the idler, around the motor pulley, and back to the gripper.
- Make sure the motor pulley is at the correct height, and then secure it with the grubscrews.
- Make sure that everything is lined up correctly, both sides of the belt when taught should be parallel. You may need to remove the 623 bearings to move the Y idler.
- Holding the Y carriage, pull the belt taught and insert it into the provided space in the half of the gripper. Any excess can be fed through the slot in the gripper and trimmed.
- If you are installing anything else into the bottom parts of the X axis extrusions, slot the nuts for them now.
- Slot 2 nuts into the bottom of each of the X axis extrusions.
- Install the printer supports. You can either add the feet or adhesive-backed rubber feet to these.
- Flip the printer back around onto its feet.
X Axis
This is a work in progress, containing some of my notes for assembly.
If you don't have T-slot nuts, SAE 6-32 nuts will fit into the 2020 extrusion and work with http://www.thingiverse.com/thing:75942, scaled around 107% in the X dimension. I found that 3/8" round screws with a single #6 washer are just long enough for most of the installations. If using flat screws, you need 1/2" instead and a washer.
The long 2020 extrusions are for the Z axis.
If you are using nuts that need to be slotted in, plan ahead for how many nuts you need in each section.
If you forgot to install the 623 bearings into the X idler, you can use an 8mm hex key as a shim to aid in getting them in.
