Duet Web Control
Revision as of 18:15, 12 March 2016 by PRZ (talk | contribs) (pres)
The web interface
While Duet board could be handled with a command program on your PC communicating by USB with the board as traditional in 3D printing, a web server (Duet Web Control – DWC) exist on the Duet, is the choice of most users and a major asset of the RepRap firmware. A capable server integrated in the main printer board is now (March 2016) without equivalent. Connecting via Ethernet allow communication with the web server to drive the printer. Installing an Ethernet Wi-Fi bridge will allow connection with any Wi-Fi enabled device. All printing is done after uploading G-code file on the board SD card, which benefits from the fast Ethernet communication of the Duet (up to 350~400 kb/sec with a good SD card).
Principle of operation
This web server, operated by program files located on the SD card, is somewhat independent from the firmware stored on the board flash memory. First, the web server shall connect to the firmware, which is automatic while opening the web server, and could be forced with the button "Connect" if communication is lost (which occurs regularly). The server send commands to the board firmware and get information from answers to a small set of commands ( M408, M105, M20, M36) according to a specific protocol. The browser window layout adjustment is mainly automatic, based upon the printer configuration as reported by firmware.
How does it looks
Main tab is : "Machine control" tab. Note that if the calibration button is not available, you will restore it with a "Zoom out" of the window.
Machine Control tab
While you could upload files to print in the "G-codes Files" tab, it is often wise for up-to-date files to use the first line button "upload and print".
Print Status tab opens automatically while the printing starts.
Print Status tab
To send G-code or check calibration result, you will use the G-code console tab
G-code Console tab
To upload or execute G-code file, the G-code Files tab:
G-code Files tab
To configure the web server, the 'Settings' tab:
Settings tab
First start
If Netbios names are recognized on your network (most network do), you can simply connect to the web server using the printer name as defined in the 'config.g' file. e.g. http://lily. Name is not case sensitive. Note that in the config.g file the first letter ‘P’ indicates a parameter and is not part of the name.
Alternatively, you can connect to your printer with its IP address, e.g. http://192.168.1.14 . In that case, you will prefer to define a static IP address (and IP mask) in config.g file.
Note that you could open multiple sessions of the web server and could operate from multiple machines.
Many printer can coexist in the same network, provided you define a specific MAC address for each printer.
Languages
Default language is English, but other languages are available (in Settings tab): German, French, Spanish, Swedish and Chinese. New translation could be added while modifying the '/www/language.xml' file.
Configuration
In the "settings" tab, you could modify some parameters, but these modifications are not permanent and you shall modify the file "/www/js/model.js" to have permanent modifications. This file replace the former "interface.js" file which was splitted in "model.js" (configuration) and "viewmodel.js" (execution) from DWC version 1.08. Updating this file is done like updating the config.g file
Note that the web server use a password, which shall be the same as the one defined in the config.g (default password: RepRap). A modified password is needed if your network is connected to wifi.
Christian Hammacher (Chrishamm) write and maintain the present web server on GitHub. It also maintain own fork of the RepRap firmware, as the web server improvement may need new firmware functions or modifications. DC42 firmware fork have frequent exchanges with the Chrishamm fork and they are very similar. Chrishamm also added useful functions on the RepRap firmware, notably recently the capability to do firmware update from the web interface.
