Duet
Revision as of 16:07, 31 March 2014 by T3P3 (talk | contribs) (Open hardware)
Duet
Duet - Arduino Due Compatible 3D Printer Electronics
CERN OHL
About
The Duet was developed by Andy and Tony from Think3dPrint3d in conjunction with RepRapPro and with much advice from Chris Palmer (Nophead)
The Duet is a 3D Printer controller board that is compatible with the Arduino Due. This 3D Printer controller combines the Arduino Due microcontroller with 4 stepper motor controllers, Ethernet, Hi-Speed SD card slot and more.
Overview
The Duet runs the 32 bit, ARM core SAM3X8E microprocessor, as found on the Arduino Due. This is a step change from preceding controllers using 8 bit microprocessors and leaves loads of overhead to do cool things (like running a webserver or running delta bots much faster). The Duet comes with Ethernet built in allowing it to run as a network printer controller, along with USB and an SD card (fully SD 2.0 compliant). In addition it takes the Duex4 expansion board for a further 4 stepper channels - for a total of 8 axis controls (3 axis + 5 extruders for example). A more in-depth description can be found in this blog post
The wiring for the Duet and Duex4 expansion board is as shown:
Duet Duex4 wiring.svg
Open hardware
The Duet hardware design is licensed under the CERN OHW License 1.2: the design is free to be distributed and modified within the terms of this license. All the design files are available on Github. The Duet was completely designed using the Open Source software package KiCAD so hacking and building on this design is accessible to all.
Software
The Duet runs RepRap Firmware, a new C++ firmware by Adrian Bowyer. The software supports receiving GCode from over the USB serial port, from the SD card and from the ethernet interface. Additionally, the firmware can be compiled with the Arduino IDE or Eclipse and uploaded like other firmware.
RepRapPro have released a video showing the web interface in use with the Ormerod printer.
The software is adding new features daily, for example support for multiple extruder printing - see the T3P3 github, RepRapFirmware, multi extruder branch.
The Think3dPrint3d blog has a post on how to setup Eclipse to modify and compile the firmware with printer specific options, the ultimate aim to to have all printer specific options set by g-code.
Where to get it
Think3DPrint3D Duet & Duex4
Reprap Austria Duet & Duex4
Here is a picture of a 4 colour print from the Duet and Duex4 expansion board combo, and a picture of the set-up:
Further reading
