Drive-gear
Revision as of 04:00, 16 September 2013 by 3dprinterkit (talk | contribs) (Undo revision 104582 by 3dprinterkit (talk))
Drive-gears to be used in direct drive and some other extruders (like the Adrian's_Geared_Extruder).
Model | From | Length | Outer diam. | Hob diam. | Bore | Approximate Cost | Additional notes |
fabberworld.com MK7 Drive Gear |
Switzerland | 11,2 mm | 12,75 mm | 11,22 mm | 5 mm | 12.50 CHF | The best drive gear on the market. Made in stainless steel and are good for both 1.75 and 3.00mm filament. |
RepRap.me MK7 Drive Gear |
EU/Denmark | 11 mm | 12,5 mm | 10,56 mm | 5 mm | 11 $ | The best drive gear on the market. Made in stainless steel and are good for both 1.75 and 3.00mm filament. |
RepRap.me MK8 Drive Gear |
EU/Denmark | 11 mm | 9 mm | 7 mm | 5 mm | 11 $ | MK8 is a new evolution of the MK7 Drive Gear. The smaller diameter gives 35% more power. Made in stainless steel and are good for both 1.75 and 3.00mm filament. |
Mendel-Parts hobbed shaft stainless-steel insert brass insert |
Netherlands | ? mm | ? mm | ? mm | M4, M5, M6 5,1 mm |
14 € 4€ 3€ |
stainless steel |
QU-BD | US | 11.03 mm | 11.64 mm | 10.5 mm | 5 mm | 7,50 $ | Brass alloy. (maybe better suited for 3mm than 1,75mm) |
RepRapWorld | Netherlands | 10 mm | 12 mm | ? mm | 5 mm | 8 € | "mk7 compatible" |
Mini-hyena | Hungary | 13 mm | 8 mm 11 mm 11 mm 13 mm |
6 mm 9 mm 9 mm 11 mm |
5 mm 5 mm 8 mm 8 mm |
12 $ | made by Arcol ! |
TrinityLabs hobbed pulley | US | 11 mm | 13 mm | 11 mm | 5 - 8 mm | 8$ | by BLDDK (you may ask him or ezmobius on the IRC |
Makemendel | India | ? mm | ? mm | ? mm | M5 | $5.50 USD | |
Brass insert | |||||||
Conrad.com Conrad-uk |
EU UK |
? mm | ? mm | ? mm | M4 | 3 € 4 £ |
Maritime-models | UK | ? mm | ? mm | ? mm | many | 1,80 £ | need some use to grip more effectively |
Paoparts | France | 15 mm | ? mm | 8 mm | M4 | 5.30 € | |
Voelkner | Germany | ? mm | ? mm | ? mm | M5 | 2.95 € | |
Pb-modelisme | France | ? | ? | ? | 5 mm | 3,50 € | |
Ok-modelisme | France ? | ? | ? | ? | 5 mm | 3,30 € |
