DocumentationMain
Revision as of 05:53, 30 January 2006 by ZachSmith (talk) (version migrated from twiki)
Current Documentation
The most current version of the RepRap documentation. These documents are what you want to use if you wish to construct your own.
Extruder Mk II
The extruder is a core component of the RepRap project. It is the part that feeds, melts, and extrudes the working material in a fine stream. It is basically the print head.
PICCommsLibrary
The PIC Comms Library is used to ...
JavaCommsLibrary
The Java Comms library is used to talk to PIC devices using the PICCommsLibrary.
Stepper Motor Controller
The Stepper Motor Controller library is used to control unipolar stepper motors.
Developer Documentation
This area is intended for developers actively working on the RepRap project. Information on how to contribute, tips on various developmental things, etc.
Archived Documentation
Earlier versions of various RepRap documentation preserved here for historical reasons.
ReallyOldStuff
Here you can find stuff from the really early days of RepRap. It's been moved here so the documentation page stays clear and concise.
