DeviceMessages
Revision as of 06:35, 11 January 2015 by Glenn (talk | contribs) (catchg)
Device Messages
All devices:
Get Version
Request message: 0
Additional parameters: None
Reply: 1 byte: Minor version
1 byte: Major version
This is a mandatory message that must be supported by all devices. It returns the version number as two bytes; the minor and major version numbers.
Motor devices (suggestions only):
The following are the messages currently implemented on the sample DC and stepper motor drivers.
Forward
Request message: 1
Parameters: 1 byte: speed (0-255)
Reply: None
Reverse
Request message: 2
Reply: None
Set position counter
Request message: 3
Parameters: 2 bytes: big-endian integer representing the motor position
Reply: None
Get position counter
Request message: 4
Parameters: None
Reply: 2 bytes: big-endian integer representing the motor position
Seek to position
Request message: 5
2 bytes: big-endian integer representing the motor position to seek to
Reply: None
Release torque
Request message: 6
Parameters: None
Reply: None
This differs from setting the speed to 0 in some cases (such as a stepper motor) because not only does it stop, but it sets the motor into a power-off mode where it won't hold its position and it can free-spin.
All other messages are currently unallocated. Please record them here as you define any.
