Darwin
<accesscontrol>RepRapDevelopers,,anon(ro),,</accesscontrol> If you wish to submit patches, changes, bugfixes, or new work, please create a new page in our Experimental Lab or contact a developer.
The current release of the RepRap Self-Replicating 3D Printer is called Darwin.
Cartesian Bot
These .stl files describe the Cartesian Bot. The Cartesian Bot is the 3-axis positioning system which forms the body of Darwin, the RepRap Printer.
Use your RepRap (or some other kind of 3D printer) to make these parts. Then use them to build a new RepRap Printer.
Thermoplast Extruder
These .stl files describe the Thermoplast Extruder. The Thermoplast Extruder is the heart of the Darwin RepRap. Similar to a motorized hot glue gun, it builds up parts layer by layer. Use your RepRap (or some other kind of 3D printer) to make these parts. Assemble them to make a new Theroplast Extruder, and then use that as part of your new RepRap Printer.
Laser-Cut Parts Files
Use a Laser-cutter to make these parts. Then use them to build a new RepRap Printer.
Art of Illusion Files
These files were created using the 3D modeling program Art of Illusion (AoI). (Available for most operating systems!) Use AoI to edit the numerous .aoi files here, or to export them as .stl files, and then print the .stl files with your 3D printer. (And then build a new RepRap Printer).
Ignore the following, it needs editting.
- We're using a SubPageList here. See for details, http://www.mediawiki.org/wiki/Extension:SubPageList3
- Horizontal layout, including all descendents (silly, but possible). Order is by edit date.
<splist
parent= sort=asc sortby=lastedit liststyle=bar showpath=no kidsonly=no debug=0 showparent=no
<splist
parent= showparent=yes sort=desc sortby=title liststyle=ordered showpath=no kidsonly=no debug=0
