Comparison of Electronics
Revision as of 20:00, 26 January 2015 by Traumflug (talk | contribs) (Remove AZSMZ mini, because closed source (according to AZSMZ Mini))
At the date of this edit ( May 2012 ), the IRC channel recommends RAMPS as feature-rich, Sanguinololu as "just works" and Gen7 for the do-it-yourselfer. You can always go there and ask for additional advice, of course.
Board | License | Latest Version |
Extruders | Fans | Heaters | Endstops | Temp sens | SPI | I2C | RS485 | ISP | CPU | CPU Speed ( Mhz ) | Stepper driver | Other features |
RAMPS | GPL | v1.4 | 1-2 | 3 (maximum, shared w/ Heaters) | 3 (maximum, shared with Fans) | 6 | 3 | Yes, future | Yes, future | No (via Arduino: Yes) | No (via Arduino: Yes) | Arduino Mega 8 bits ATmega1280, ATmega2560 | 16 | A4988, Pololu boards | |
Sanguinololu | GPL | v1.3a | 1 | 3 | 2 | 3 | 2 | - | 1 | - | 1 | 8 bits ATmega644P (or ATMEGA1284) | 16 | A4988, Pololu boards | |
STB_Electronics | GPL | v1.1 | 1 | 1 | 2 | 3 | 2 | - | - | - | 1 | 8 bits ATmega1284P | 20 | A4988, Pololu boards | Built in SD-Card, 128x64 graphic LCD, clickwheel, USB |
easy electronics | GPL | v2.0 | 2 | 2 | 3 | 3 | 3 | - | - | - | 1 | 8 bits ATmega1284P | 20 | A4988, Pololu boards | micro SD-Card, 128x64 graphic LCD, clickwheel, USB |
Marlin Electronics | GPL | V0.1 | 3 | 2 | 4 | 3 | 4 | 1 | 1 | 0 | USBstick / SD-card / FTP | 32 bit ARM + FPU (STM32F4) | 168 | TMC260 | micro SD-card, Ethernet, USB host + device, Diagnostics, TFT display + capacitive touchscreen. |
Melzi | GPL | v2.0 | 1 | 1 | 2 | 3 | 2 | 1 | 1 | 1 | 1 | 8 bits ATmega1284P | 16 | A4982 | |
Megatronics | GPLv2 | v1.0 | 1-2 | 1 | 2 | 6 | 4 | Yes | Yes | No | Yes | 8 bits ATmega1280 | 16 | A4988, Pololu boards | |
Printrboard | CC ShareAlike 3.0 | v0.7 | 1 | 1 | 2 | 4 | 2 | 1 | 1 | ? | USB | 8 bits AT90USB1286 | 16 | A4982 | |
Teensylu | GPL | v0.7 | 1 | 1 | 2 | 4 | 2 | 1 | 1 | ? | USB | 8 bits AT90USB1286 | 20 | Pololu boards | |
Ultimaker Electronics | GPL | v1.5.4 | 1-2 | 3 | 3 | 6 | 3 | - | - | - | - | Arduino Mega 8 bits ATmega1280 | 16 | A4988, Pololu boards | |
Generation 6 Electronics | GPL | v1.0 | 1 | 0 | 2 | 3 | 2 | 1 | 1 | 1 | 1 | 8 bits ATmega644P | 16 | DRV8811 | |
Generation 7 Electronics | See page | v1.5 | 1 | 0 | 2 | 3 | 2 | - | - | - | 1 | 8 bits ATmega644(P), 1284P | 20 | A4988, Pololu boards | |
4pi from Kliment[1][2] | GPL | beta | 1-2 | 2 | 3 | 6 | 4 | 1 | 1 | ? | ? | 32 bit ARM ( SAM3U ) | 96 | A4982 | |
SmoothieBoard | GPL | 1 | 1+ | 2+ | 2+ | 6 | 4 | 1 | 1 | ? | ? | 32 bit ARM ( LPC1769 ) | 120 | A4982 | MicroSD card, file-based config, digital current control, USB composite ( serial + mass storage ), Ethernet, multiple connector options, support for multiple arm solutions ( delta/hbot ) and tools ( extruders, lasers ) |
Azteeg X1 | CC ShareAlike 3.0 | v1.5 | 1 | 1 | 2 | 3 | 2 | 1 | 1 | - | 1 | ATmega1284P(644P on v1.0) | 16 | A4988, Pololu boards | |
Azteeg X3 | CC ShareAlike 3.0 | v1.2 | 2 | 4 | 3 | 6 | 3 | 1 | 1 | - | 1 | ATmega1280/2560 | 16 | A4988, Pololu boards | |
R2C2 electronics | CC Non Commercial | v1.2 | 1 | 1 | 2 | 3 | 2 | 2 | 1 | ? | USB | 32 bits ARM ( LPC175x ) | 100 | A4988 | |
Pololu Electronics | GPL | ? | ? | ? | ? | ? | ? | ? | ? | ? | ? | Arduino Mega 8 bits ATmega1280 | 16 | A4988, Pololu boards | |
Generation 3 Electronics/Tech Zone Remix | GPL | ? | ? | ? | ? | ? | ? | ? | ? | ? | ? | 8 bits ATMEGA644P | 16 | A3982 | |
Monotronics | GPL | ? | ? | ? | ? | ? | ? | ? | ? | ? | ? | 8 bits Atmega644P | 16 | ? | |
Phoenix | CERN Open hardware license | ? | 3 | 2 | ? | ? | ? | ? | ? | ? | ? | 8 bits Atmega644P | 16 | TB6560 | |
Brainwave | GPL | 1.0 | 1 | 1 | 1 | 3 | 2 | - | - | - | ? | 8 bits AT90USB646 | 16 | LV8713T | |
RAMBo | CC ShareAlike 3.0 | 1.1b | 2 | 2 | 2 | 6 | 4 | 1 | 1 | 0 | USB | Atmega2560, Atmega32u2 | 16 | A4982 | all-in-one RAMPS board, marlin FW, digipot, extra ports |
RUMBA | GPL | 1.0 | 3 | 2 | 3 | 6 | 4 | ? | 1 | 0 | USB & ISP Headers for both microcontroller | 8 bits Atmega2560, Atmega16u2 | 16 | A4988, DRV8825 Pololu boards | all-in-one RAMPS board, marlin FW, sprinter, repetier, JTAG Breakout |
MKS MINI | GPL | 1.1 | 1 | 1 | 1 | 6 | 2 | ? | 1 | 0 | USB & ISP Headers for both microcontroller | 8 bits Atmega2560, 16U2 | 16 | DRV8825 in board | all-in-one board , marlin FW, sprinter, repetier, others refer to http://reprap.org/wiki/MKS_MINI |
MKS BASE | GPL | 1.1 | 2 | 1 | 2 | 6 | 3 | ? | 1 | 0 | USB & ISP Headers for both microcontroller | 8 bits Atmega2560, FT232RL | 16 | A4982 in board | all-in-one board , marlin FW, sprinter, repetier, others refer to http://reprap.org/wiki/MKS_BASE_1.0 |
MKS GEN | GPL | 1.1 | 2 | 1 | 2 | 6 | 3 | ? | 1 | 0 | USB & ISP Headers for both microcontroller | 8 bits Atmega2560, FT232RL | 16 | A4988, DRV8825 | all-in-one board, marlin FW, sprinter, repetier, others refer to http://reprap.org/wiki/MKS_GEN_V1.1 |
Duet | CERN OHL | 0.6 | 5 with Duex4 | 1 (up to 5 with Duex4) | 6 with Duex4 | 4, 8 with Duex4 | 6 with Duex4 | 1 | 2 | 0 | JTAG | 32-bit ARM SAM3X8E microprocessor, same as Arduino Due. | 84MHz | Allegro A4982 | Ethernet, USB, SD card |
Alligator Board | CC-BY-NC-SA | 1.1 | 1 (up to 4 with expansion) | 2 | 2 (up to 5 with expansion) | 6 | 2 (up to 5 with expansion) | 0 | 0 | 0 | JTAG, USB | 32 bit Cortex M3 ATSAM3X8EA, (arduino-Due Compatible) | 84MHz | Texas Instrument DRV8825, with firmware configurable current | Ethernet, dual USB, microSD card, Raspberry-PI, Expansion Connectors |
RADDS | CC BY-NC-SA 3.0 | 1.1 | 3 | 6 (maximum, shared w/ Heaters) | 6 (maximum, shared w/ Fans) | 6 | 5 | yes | yes | RS232 | No (via
Arduino: Yes) |
32-bit ARM SAM3X8E Arduino DUE | 84MHz | A4988, DRV8825 Pololu boards | USB, SD card
SAV_MKI | CC BY-SA | Rev.C | 1 | 3 | 2 | 4 | 2 | 1 | 1 | ? | 1 | 8 bits AT90USB1286 | 16 | Pololu boards | uSD, A4988, DRV8825 pololu boards, native USB, BT interface (though dongle), Marlin, LCD companion board SAV 3D LCD |
Replicape | CC BY-SA | Rev A4A | 2 | 3 | 2 | 6 | 3 | 1 | 1 | 0 | 1 | 32 bit ARM Cortex-A8 | 1000 | DRV8825 | uSD, 4GB flash (on BBB), USB host, Ethernet, PRU: 200 MHz co processor, LCD companion board Manga Screen |
Aakar Motherboard | CC BY-SA | Rev .B | 3 | 2 | 1 | 6 | 4 | 1 | 1 | 0 | 1 | 32 bit ARM Cortex-M3 | 100 | Pololu Boards | MicroSD card, file-based config, USB composite ( serial + mass storage ), Ethernet, onboard AC relay, SPI GLCD 128x68, flexible power options |
Extruders | Fans | Heaters | Endstops | Temp sense | SPI | I2C | RS485 | ISP | CPU | CPU Speed ( Mhz ) | Stepper driver | Other features |
Further reading
- The above chart compares "complete" RepRap electronics systems -- the stepper motors plug into one side, and the USB cable from the laptop plugs into the other side. Such systems often include 4 identical stepper driver boards, one for X, Y, Z, and Extrude motors. For a chart comparing stepper driver boards, see stepper motor driver#Stepper drivers.
- After you get a set of electronics, you may want to read Testing RepRap Electronics.
- Ideas for better electronics? Please add your ideas for making things better to ideas to place or Vaporware Electronics.
- If you have ideas for better firmware running on the electronics, please add your ideas to FirmwareWishList.
- Think you can design better electronics, please feel free to use the ideas at ideas to place, FuturePlans, Vaporware Electronics, FutureToolIdeas, Alternative Electronics, Development Pathway, etc. Feel free to create a new wiki page to document your new electronics. Feel free to add your designs to the list at list of electronics, and the above chart.
