Clone wars: Rostock
Language Issue/s on this page!
This article needs translation into English.
This article is written in a language other than English. As it is intended for readers from the RepRap community, Alternate translations are encouraged. In particular, an English translation is required. Please see the layout and translations of the http://www.reprap.org/wiki/Main_Page as an example of how this should be achieved. in short you should follow these conventions: If your page is called XXXXX, and is not in english, please do the following:
- add a languages header to the page, using
{{Languages}}
- copy the non-english content from the "primary" page to the appropriate language page. For example, if your content is in Deutsch, move the content from XXXXX to XXXXX/de
- revise the original XXXXX page to be english-only, except for the "Languages" header.
Introducción
La Rostock es una impresora de tipo Delta
Piezas imprimibles
Estructura completa
Imagen | Pieza (STL) | Cantidad | Tiempo impresión | Comentarios |
idler_end_rs | 3 | 52 min | Pieza de idler_end | |
carriage_rs | 1 | 1h 1min | Pieza de idler_end | |
platform_rs | 3 | 40 min | Pieza de la plataforma | |
jaws_rs | 12 | 5 min | Pieza de jaws
Solo necesario si no se utiliza las varillas | |
joint_rs | 12 | 3 min | Junta | |
rod_rs | 6 | 30 min | Varillas | |
penholder_rs | 1 | 31 min | Pieza de penholder | |
motor_end_rs | 3 | 1h 34 min | Pieza de motor_end | |
endstop_rs | 3 | 14 min | Pieza del endstop |
Extrusor
100px | [] | xx | xx | xxx |
Fotos
Actualizaciones
Vitaminas
Imagen | Pieza | Cantidad | Precio unidad | Precio total | Tiendas | Comentarios |
Varillas roscadas
Varillas Lisas
Endstops
Instrucciones
Todavía No hay instrucciones oficiales, pero entre todos lo iremos sacando
Enlaces
- Animación del funcionamiento de la impresora
- RepRap Rostock
- Airtripper's Bowden Extruder
- RepRap Rostock thingiverse
- Airtripper's Bowden Extruder thingiverse
Proyecto Clone Wars |
