Choosing a Power Supply for your RepRap
The power supply (PSU or Power Supply Unit) is a most essential component of any RepRap, yet the information over which PSU to choose/buy for RepRap use is very much scattered around the web, in YouTube videos, and in various forums, blogs and wikis. Also there is little information concerning safety issues and these should be the absolute priority when dealing with PSUs.
The purpose of this page is to help the RepRap builder choose a proper PSU for her/his project, possibly modify it slightly to function with her/his choice of RepRap electronics, and deal with any safety concerns that may arise related to the PSU.
- 1 Switch-mode power supplies, a short introduction
- 2 LED strip PSUs or ATX PSUs ?
- 3 PSU power requirements for RepRap use
- 4 What to look for in an ATX PSU for your RepRap project
- 5 Ten Quick Steps to Modifying an Inexpensive ATX PSU for RepRap Use - with pictures!
- 5.1 Unboxing
- 5.2 Tools and materials required
- 5.3 Preliminary Test
- 5.4 Opening the ATX PSU
- 5.5 Visual inspection of the PSU innards
- 5.6 Cutting unnecessary cables
- 5.7 (optional) Solder the 3.3V_Sense wire
- 5.8 Close the ATX PSU and visual check
- 5.9 (optional) Braid cables
- 5.10 Add terminal block strip(s) and final test
- 6 Using an ATX PSU for your RepRap project without modifying it (and without voiding its warranty)
Nowadays (2014) practically all power supplies within the power range required by RepRap printers (250~350W) are switch-mode power supplies (as opposed to linear power supplies, which are considered technologically outdated). Switch-mode power supplies have relatively complex circuits that convert mains AC electricity to the DC voltages required by RepRap steppers and electronic circuits. The design and manufacturing of switch-mode power supplies is way beyond the reach of any hobbyist, leaving a single alternative for RepRap builders: to buy a commercial switch-mode PSU.
Economies of scale play an important part in determining the price and availability of a switch-mode power supply. Consequently, industrial-grade switch-mode power supplies (e.g. those used in CNC machines) manufactured in small series and to high standards of reliability, are extremely expensive and have limited availability, ruling out their use for DIY RepRaps. So when looking to buy a PSU for her/his RepRap, the RepRap builder has in reality just two choices: either what can be called the LED strip PSU, or a modern ATX PSU. Both are switch-mode power supplies easily bought in retail commerce, but they differ essentially in the purpose for which they are designed, manufactured and sold.
LED strip PSUs
LED strip PSUs are switch-mode PSUs designed to supply a fixed DC 12V or 24V rail with relatively high current capabilities (anywhere from 15A to 30A or more) to a strip of dozens or hundreds of LEDs, each consuming a small percentage of the total current. In the last couple of years, due to the development of LED lighting, they have become relatively inexpensive and are now widely available. They are even currently included in many commercial RepRap kits. However, one must keep in mind their original design requirements: powering LEDS is not a particularly difficult task, as these are relatively forgiving electronic devices. Also, since LED strip PSU manufacturers are not forced to comply with any specific requirements or standards apart from the basic ones that will get them through the usual test laboratories certifications, there is a big variation in quality and price, and it is practically impossible for the hobbyist to choose one LED strip PSU over another on any rational basis.
ATX PSUs
ATX PSUs on the other hand have been around for decades, have been produced consistently in hundreds of millions of units over many years, and have evolved over time, adapting to the ever-changing PC market. There is an "official" ATX PSU design guide / specification that is revised every few years and that is available as a PDF document for free download. ATX PSU manufacturers can claim that their products conform to these specifications (or not) as this is seen as an attractive feature for consumers. The latest ATX specification revisions include not only precise technical specifications, but also a number of safety requirements as well as some ergonomic requirements. ATX PSUs get regularly opened and dissected in specialized hobbyist websites (JonnyGuru, TechPowerUp, HardwareSecrets, etc), and some brands have established themselves as having reliable products with a good price/performance ratio. So all in all, there is a lot more information available to the hobbyist to make a rational choice when choosing an ATX PSU.
Comparison table
The following table compares LED strip PSUs vs ATX PSUs for RepRap use:
LED Strip PSUs | ATX PSUs | |
Availability | widely available | very widely available |
Price | $20-$120 | $20-$200 or more |
Power | 200W-400W | 200W-600W or more |
PFC (see below) | No (not required) | Passive or Active PFC (or no PFC at all) available |
Thermally regulated fan | No (not required) | Yes (12 or 14cm diameter) |
Guaranteed minimum efficiency | No (not required) | Yes |
Cables included | No | Yes |
Low ripple/noise DC output | No (not required) | Yes |
Excellent load/line regulation | No (not required) | Yes |
Requires modifications for RepRap use | No | Depends, but in general, a few simple modifications (and this voids the warranty) |
Protections | Few(?) | Many |
Remote softstart and standby | No | Yes |
On/Off switch | No (usually) | Yes (usually) |
24V versions available | Yes | No |
Established brands | No | Yes |
PFC
PFC, which stands for Power Factor Correction, is a highly desirable feature for any switch-mode PSU, and a good indication of the quality and engineering that has gone into the design of a PSU. When it comes to ATX PSUs, nowadays (2014) only the very cheaply manufactured models (which BTW are not suitable for RepRap use) do not have some form of PFC. Active PFC is preferable to passive PFC, although it does increase the complexity and price of a PSU. Explaining what PFC is and what it does in details is beyond the aim of this wiki, but you can read this article for more information: Power Supply Fundamentals on silentpcreview.com, scroll down to the PFC section.
RepRap electronics (e.g. the ubiquitous Arduino Mega 2560 + RAMPS_1.4 combo) usually require +12V to function and the same voltage is used for the heated bed (if present), extruder heater(s) and steppers. Each electrical or electronic part draws a certain current and by totaling these currents and using the formula Power (Watts) = Voltage (V) x Current (A), we get the power requirements for our PSU, whether we are using an LED strip PSU or an ATX PSU (for the 12V rail, see below). Following good engineering practices means we'll also add a safety margin and slightly overspecify our PSU power requirements.
Another way to calculate our total current and hence total power requirements for the PSU is to check the fuse or fuses that protect our RepRap. For example, on a RAMPS_1.4 board there are two PTC resettable fuses: one is a 5A fuse for the electronics, extruder(s) and steppers, the other one is an 11A fuse exclusively for the heatbed. So the maximum current draw from our Arduino Mega 2560 + RAMPS_1.4 combo would be 16A. We'll add a 25% safety margin and that gets us to 20A, or 12V x 20A = 240W. So, we should look for a PSU that can deliver a minimum of 20A @ 12V = 240W. However note that you should not necessarily select a PSU that just meets these power ratings, as it would operate near its maximum capacity. Anything that exceeds these power requirements will work but if you can afford it, buy a PSU that exceeds the minimum power requirements by 30% or more.
There are scores of ATX PSUs that will fit within any power range, from various brands and in various lines. To help with your choice of ATX PSU for your RepRap project, here is a short list of desirable features:
- Exceeds the previously calculated (see above) minimum power requirements by 30% or more on its 12V rail(s).
- Has PFC. Preferably active PFC.
- Has a temperature controlled fan, 12cm (good) or 14cm (better).
- Has a guaranteed efficiency rating. Nowadays (2014) manufacturers have standardized over some efficiency labels such as Bronze, Silver, Gold and Platinum. Bronze is more than good enough for RepRap use.
- Has a Power On/Off switch.
- "Haswell compatibility" (explained below).
- Comes from a generally recognized manufacturer and has received positive reviews from hobbyist websites (such as those mentioned above).
Once you have decided on a realistic budget, it should be easy to find and purchase online an adequate ATX PSU for your RepRap project with all the desirable features listed above. One tip: don't even waste time considering ATX PSUs at the "bottom of the heap" i.e. those $20 noname ATX PSUs you can find on eBay, or some old second hand ATX PSU. For a few extra dollars or euros you can certainly find much better quality stuff, new in the box, and that's what you'll want to use in your RepRap project.
Haswell Compatible PSUs
At the end of 2014 most if not all ATX PSUs being sold in retail are probably labelled "Haswell compatible". What this means in practical terms is that these power supplies will not shutdown, fail to start or lose regulation with very small power loads. The advantage for RepRap builders is that these ATX PSUs will in general also work without problems with the unbalanced (12V mostly) loads presented by RepRaps.
Let's get hands on with an ATX PSU for our RepRap! In this case I took pictures of the modifications I made to an inexpensive ATX PSU I bought here in Spain in September 2014 for my P3Steel RepRap project, which uses the ubiquitous Arduino Mega 2560 + RAMPS 1.4 combination as its electronics. The total time required to modify an ATX PSU will of course vary but I would estimate it at around one evening, working at a leisurely pace. The following are generic instructions that apply in principle to any modern ATX PSU, you don't necessarily have to buy the same model as shown below.
Note that by clicking on any of the thumbnail pictures below you have access to the full-size version (in case you want to check any detail).
Unboxing
Here is the ATX PSU, still in its fancy box:
The back of the box lists the technical specifications and features for this ATX PSU. Note that despite the wonderful claims on the fancy box, this particular ATX PSU model only has passive PFC (doh!) and no guaranteed efficiency rating (bummer!), but it has a 140mm thermally regulated fan (good!) and it's painted black (just kidding!).
Let's take it out of the box and check what's included:
Well, we have the ATX PSU properly packaged in bubble wrap, a power cable (EU type, and really short as I found out later), a small plastic bag with four screws and... no manual or warranty certificate! The cables could be a little bit longer but they have an adequate length for RepRap use. They are not sleeved, but we'll work around that later. Also note there is a plastic protection for the cables exit from inside the PSU. And finally: 200~240V AC only (which is fine for Spain and most of the EU).
Yet another thing we can check during the unboxing is the wire gauge used for the cabling of our ATX PSU. Usually we'll find 22AWG to 16AWG cables in ATX PSUs (the smaller gauge the better), this one uses 18AWG and 20AWG (we are going to use 2x20AWG for our 12V@5A rail and 2x18AWG for our 12V@11A rail).
The label on one of its sides indicates the maximum power available for each rail. For RepRap use, the relevant figure we have to look for is the rating for the 12V rail, in this case, 27A or 324W: we are good! Also note the back of the ATX PSU has a proper On/Off switch and power cord receptacle. Again, good.
Make sure you have all of these at hand before you get started!
- Multimeter.
- Small cutting pliers and long-nose pliers.
- Screwdrivers.
- Soldering iron and some solder.
- 47 Ohm resistor (1/8W or 1/4W or 1/2W etc; any size will do).
- Terminal block strip (12 position, or 2 x 6 position).
Preliminary Test
It's always a good idea to make a simple, quick preliminary test of our just unboxed ATX PSU i.e. turn it on and check that it does indeed work and that we get the correct voltages on all its outputs. Let's do this in a few simple steps:
- Examine the 24-pin motherboard power connector and find the green wire. This is the PS_ON wire and we have to bring it to a low logic level to softstart our ATX PSU. To do so, we use a 47 Ohm resistor inserted between the PS_ON (green) wire and any of the GND (black) wires. DO NOT use a paper clip! Inserting a paper clip between the wrong terminals could short the PSU and damage it, and you could severely hurt yourself in the process! Also at this point, double-check that you have correctly inserted the resistor between the green wire and one of the black wires.
- Make sure the On/Off switch is in the Off position and connect the mains AC power cable. Nothing should happen at this point.
- Connect a multimeter reading DC Volts between the yellow (+12V) and black (GND) wires in one of the Molex connectors. It should show 0V at this point.
- Now switch on the ATX PSU and check the multimeter: it should show approximately 12V +/- 5%. Also the PSU fan should be spinning. Now we know that the +12V rail is working.
The picture below is from the same test on an older ATX PSU (this test was done on our sample new ATX PSU with similar results, I just forgot to take some pictures then).
If you want, also check the +5V (red wire on the same Molex connector) rail. Although the +5V rail is not really required for a RepRap, it's always a good thing to have available in case we need it.
Opening the ATX PSU
Warning 1: from this point on we are voiding the warranty of this ATX PSU. If you absolutely don't want to void the warranty of your ATX PSU, check the optional method below to connect it to your RepRap electronics.
Warning 2: YOU MUST ABSOLUTELY MAKE SURE THAT THE ATX PSU IS PHYSICALLY DISCONNECTED FROM THE MAINS AC POWER BEFORE OPENING IT AND DURING THE ENTIRE TIME IT IS OPEN. FAILURE TO DO SO EXPOSES YOU TO SEVERE ELECTRICAL SHOCK! Also, please wait 10 minutes after disconnecting the ATX PSU from mains AC power for the PSU's capacitors to discharge. This isn't strictly necessary nowadays since all modern ATX PSUs should have a circuit that self-discharges the bulk capacitors, but it doesn't hurt to be extra-careful.
In general, ATX PSUs are held together by just four small screws. Note that in the picture below, one of the screws is covered by a QC adhesive label, which we are just going to scratch away:
We now have removed the four screws, but the case still won't come apart!
The two case halves are held together by pressure. Gently pry the case open with a flat screwdriver:
When the two case halves finally separate, be careful not to pull too strongly on the short fan cable!
We have opened the ATX PSU and voided its warranty, so it doesn't hurt to take a look inside, right? First things first, note the exposed solder joints at the back of the power switch and power cord receptacle. This is why the PSU must absolutely be disconnected from mains power before you open it!
At this stage you should disconnect the connectors for the fan and passive PFC coil (not present if your PSU has active PFC). Use long-nose pliers for this, and be careful not to accidentally bump into other components on the PCB.
Let's take a closer look at the wires we are going to cut and those we aren't going to touch:
Purple: +5V_Standby, keep.
Grey: Power_Good, cut.
Green: PS_ON (wrongly labeled RC here), keep.
And here we see something unusual: there are two sense lines, one is labeled +S (orange) and the other is labeled -S (brown). On most ATX PSUs there is only one 3.3V_Sense line, and it usually is brown. See the discussion below about the 3.3V_Sense line, but for this particular power supply, I decided to cut the -S (brown) and keep a short (50~70mm) length for the +S (orange). Please adapt these instructions to your specific ATX PSU.
Blue: -12V, cut.
Yellow: +12V, keep all of them!
Black: GND, keep all of them.
Red: +5V, cut some, keep some! Haha! How many and which ones? Well, I kept all the +5V wires that went to the Molex connectors, and then a couple more, and cut the rest.
Orange: 3.3V, cut them all but one (used to connect to the +3.3V_Sense).
Now take a little break and come back with the cutting pliers ready for the next step!
We can now cut all the cables we deemed unnecessary in the previous step. Be careful with any surrounding components and cut the cables flush at the PCB level:
We also cut away the 12V connector to the motherboard. We are going to use these two pairs of 12V (yellow) and GND (black) 20AWG cables to make our 12V@5A rail for our RAMPS 1.4.
Cable massacre: we cut away all the cables to the main motherboard connector.
Obviously we don't throw away the cables we have just cut. Among other things they can be used to wire the heatbed for your RepRap.
ATX PSUs usually have a sense wire for the 3.3V rail; it is used to measure the voltage drop in the wires due to the high currents of the 3.3V rail, and a circuit in the PSU compensates for this voltage drop by continually adjusting the voltage of the 3.3V rail. Because modern ATX motherboards use much smaller currents from the 3.3V rail than older motherboards (from the e.g. Pentium IV era), the 3.3V sense wire and its associated circuit are not considered very important nowadays. And for RepRap use, since we don't need 3.3V for anything, it is really irrelevant.
So in theory, we could just cut the 3.3V_Sense wire flush with the PSU PCB and forget about it. However to be 100% sure would require a circuit analysis and that would mean spending a lot more time than soldering two wires together: the 3.3V_Sense wire with one of the 3.3V wires. As you can see below after soldering the two wires together they should be insulated with a bit of electrical tape or heatshrink tubing. And now we can forget about it completely!
Braiding cables is incredibly easy, requires just a few minutes of manual work, and avoids having tangles of loose wires running between the ATX PSU and the electronics of your RepRap. I recommend it, but of course this step is entirely optional. Here are a couple of pictures of the braided cables for this ATX PSU:
In the rightmost picture above you can see the various styles of braids I used: 2 strands (just twist two cables together), 3 strands (e.g. the purple, green and black braid), 4 strands (for the 12V @ 5A yellow-black braid) and 2 x 3 strands (for the 12V @ 11A yellow-black braid).
Now we just screw all our wires in the 12-position (or 2 x 6-position) terminal block strip(s) and repeat the same test as above, this time connecting the 47 Ohm resistor between the two positions in our terminal block strip that correspond to PS_ON (green) and GND (black).
It is entirely possible to use any modern ATX PSU to power any RepRap without modifying the PSU in the least (in other words, without voiding its warranty). However, this requires the purchase of some extra components which may not be easily available. Basically we'll need a female 24-pin to male 20-pin adapter cable and a couple of female Molex connectors, and of course another ATX PSU!
For this example we are going to use a be quiet! ATX PSU:
