Certification of 3D printers
Here you can find a list of 3D printers with a certificate
It is divided by process, and in alphabetical order (keep in mind when adding)
FFF
CE certificate for 3D printer
When adding :
- Keep in mind that no FFF machine can comply with the LVD(2006/95/CE) as per annex 1-2-b
- Keep in mind that to comply with the MD(2006/42/CE) the machine must either have an emergency switch or other means to put the machine in a neutral state in the same amount / or less time then an emergency switch.(a switch or only a mains connection at the back of the machine does NOT comply)
- Keep in mind that to comply with the MD(2006/42/CE) there must be a sticker on the machine that states it has CE certification
Name | Certification | sticker |
CartesioM | 2006/42/CE | |
CartesioW | 2006/42/CE | |
CartesioE | 2006/42/CE | |
Fortus900mc | 2006/42/CE |
