Certification of 3D printers
Revision as of 07:59, 19 January 2016 by Jos (talk | contribs)
Here you can find a list of 3D printers with a certificate
It is divided by process, and in alphabetical order(keep in mind when adding)
FFF
CE
When adding :
  • Keep in mind that no FFF machine can comply with the LVD(2006/95/CE) as per annex 1-2-b
  • Keep in mind that to comply with the MD(2006/42/CE) the machine must either have an emergency switch or other means to put the machine in a neutral state in the same amount / or less time then an emergency switch.(this does NOT mean a switch or mains connection at the back of the machine)
  • Keep in mind that to comply with the MD(2006/42/CE) there must be a sticker on the machine that states it has CE certification
Name Certification
CartesioM 2006/42/CE
CartesioW 2006/42/CE
CartesioE 2006/42/CE
Fortus900mc 2006/42/CE
SLS
SLA
