Canadian Suppliers
Revision as of 22:53, 23 January 2010 by Dissidence (talk | contribs)
Intro
(This is based on quoted text from Wade)
Mendel Parts
Belts and Pulleys
  • SDP/SI - "they work fine, but were pretty expensive, the shipping was expensive, and the brokerage fees were expensive too. I'd love to find a Canadian source for MXL belts and pulleys, or anything that would work."
Specific SDP-SI MXL pulleys that work on a Darwin:
Z axis - A 6A16-060DF2508 - 60 tooth 1/4 " bore pulley. Can be tapped out to M8 directly.
Electronics
  • Makerbot
  • Digikey.ca
  • Mouser (not really)
  • robotshop.ca
  • sparkfun.com
  • gadgetgangster.com
  • alltronics.com/
"Also, if you need electronics, Makerbot is my favorite, but if they're out Digikey is pretty good. They ship to Canada for $10 if you order from digikey.ca, and no brokerage fees. Mouser sent me 50 pages of customs forms detailing every single resistor, cap and chip I ordered for a Darwin, and the brokerage fees cost almost as much as the parts, so I'd stay away from them if you're in Canada."
Steel
  • Metal Supermarket
As for other Canadian suppliers, I found Metal Supermarket usually has stock of 5/16" stainless rod, which works for 8mm smooth rod.
  • Generic Steel Suppliers
Check in the telephone directory under "Steel". Your average construction steel supplier sells quite a bit of steel for prices we consider to be very cheap.
Fasteners
  • Fastenal here in Vancouver
  • Peavey Mart - good general store though they are more in the smaller cities and towns.
I've been getting M8 threaded rod from Fastenal here in Vancouver; they usually need to order in larger quantities, but it's usually pretty fast. I also get all my metric nuts and bolts there. I'm quite happy that Mendel uses fewer types of bolts, btw - that makes life a bit easier.
Also try: brafasco/CTF, Canadian Tire (although be sure to check the parts are actually what they're labeled as -- I found their inventory a little disorganized), Metal Supermarket, Atlas Machine Tools on Queen, Jacob's Hardware on Queen, and even Home Hardware in a pinch for metal rods.
Motors
  • alltronics.com/
Filament
computer parts
  • memoryexpress.com/
  • ncix.com/
Working Notes
This page may duplicate another page
We should put up a page on the Wiki regarding Canadian suppliers. I had a look at the Builders Wiki, but I wasn't sure exactly where to stick it. There's a section in the Mendel BOM regarding suppliers, but this might be more general than just Mendel parts.
