CRAMPS2.2
Revision as of 18:36, 5 January 2015 by Cdsteinkuehler (talk | contribs) (LED Polarity)
CRAMPS 2.2
Release status: Working
Cape-RAMPS for BeagleBone
GPL
KiCAD
Summary
Version 2.2 of the CRAMPS board is a mixed surface-mount and through-hole design. The fine-pitch SMT parts from version 1.0 have been removed, so all parts are now large pitch or through-hole, and are relatively easy to hand solder.
For futher documentation, see: CRAMPS
Safety
The CRAMPS board is designed to handle power levels capable of causing a fire. Be very careful with the initial board checkout, ideally using a power supply protected from short circuit and overload. Never operate your board unattended, and make sure all connected parts subject to heating (including the wires and connectors!) are far away from any potentially combustible material. Always use the proper fuses, and insure your smoke detector is working properly.
Known Issues
  • None
ECOs
  • None
Assembly
Required Tools
You must have
Soldering iron, solder, good tweezers
You really need
Solder wick, solder sucker, flux pen
Optional methods use
Solder paste, hot plate or oven
General Overview
Soldering the CRAMPS board includes both surface mount and through hole soldering.
The surface mount can be done a few ways. To hand solder, start by putting a small amount of solder on one pad. If you have flux, coat the soldered pad. Use the tweezers to hold the component down in position and heat the solder to tack the component into place (make sure the entire solder blob flows so you don't get a cold solder joint). Then solder the other pads. Also popular is using solder paste for pad by pad soldering, Oven Reflow (need link), and HotplateReflowTechnique
Solder the SMT components first, working through the parts from shortest to tallest. Then solder the through-hole parts on top of the board. Finally solder the parts on the bottom of the board.
Surface Mount Parts
100n 16V 0603 Capacitor
C301 C302 C501 C502 C503 C504 C505
These can be placed in any orientation.
10u 6.3V 0603 Capacitor
C506 C507 C508 C509
220R 0603 Resistor
R305 R401 R403 R405 R407 R409 R411
330R 0603 Resistor
R101 R102 R303
2K0 1% 0603 Resistor
R511 R512 R513 R514
2K7 0603 Resistor
R302 R402 R404 R406 R408 R410 R412
4k7 0603 Resistor
R304 R306 R307 R314 R515 R516 R517 R518
10k 0603 Resistor
R301 R308 R309 R310 R311 R312 R313 R315 R316 R501 R502 R503 R504 R505 R506 R507 R508 R509 R510
100k 0603 Resistor
R201 R202 R203 R204 R205 R206
LED Polarity
The LEDs are marked with a small polarity dot (see image) that should be aligned with the thick line on the silkscreen outline. All three LED colors have identical markings.
Yellow 0603 LED
LD101 LD401 LD402 LD403 LD404 LD405 LD406
Place with the cathode terminal (marked with a small dot) closest to the thick line on the silkscreen.
Green 0603 LED
LD102 LD301
Red 0603 LED
LD302
2N7002K FET
Q101 Q301 Q302 Q303 Q304 Q305
Place aligned with the 3 pad SOT-23 footprint.
NOTE: Q305 is not pictured on the V2.1 photo, refer to the assembly drawing for location.
DMN2075U FET
Q404 Q406
74CBTD3861
U501
Align pin 1 with the silk-screen notch and dot on the PCB.
74ACT244
U302
24C256
U301
SS14 40V 1A Schottky Diode
D401 D402 D403 D404 D405 D406
Align cathode mark with silk-screen notches on the PCB.
100u 35V Electrolytic Capacitor
C201 C202 C203 C204 C205 C206 C401
Align body notches with silk-screen outline on the PCB.
Miller Capacitors
C402 C403 C404 C405 C406 C407
These parts are optional and are are not populated by default. They are listed here so you will not worry that some SMT pads do not contain components.
In the future, parts may be populated to slow down the FET turn on/off times if necessary to avoid dI/dt issues when using alternate FETs.
Through Hole Parts
Pushbutton
SW101 SW102
HEADER_2
JP501 P102 P103 P301
HEADER_2X2
JP301
HEADER_3X2
JP201 JP202 JP203 JP204 JP205 JP206 P304
HEADER_4X2
P303 P503 P504
HEADER_6
P305 P501
HEADER_6X2
P502
POLOLU_SOCKET
P208 P209 P210 P211
KK-2.54-2W
P302 P407 P409
Place with friction lock away from the board edge. Alternately, standard pin headers or other connectors (2.54mm screw terminals, etc) can be used in place of the KK series headers shown.
KK-2.54-4W
P202 P203 P204 P205 P206 P207
Screw Terminals
Adjacent terminal blocks must be connected to form a single large block prior to soldering onto the board.
3.5mm Screw Terminal (PT 1,5-2-3,5-H & PT 1,5-3-3,5-H)
P405 P406 P408
P404
Place so the opening for the wire faces the board edge. You may also choose other connectors with the same mounting pitch.
5.0mm Screw Terminal (PT_2,5-2-5,0-H)
P201 P401 P402 P403
FUSE-HOLDER
FH201 FH401 FH402
IRLB8743PBF FET
Q401 Q402 Q403 Q405
These must be orientated as in the picture. The tall heat sink tab of the MOSFET needs to be aligned with the double-line on the silk-screen.
BB_EXP_CONN
P8 P9
SOCKET_6_LONG
P101
Do NOT populate the serial header on the V2.1 boards, or you will not be able to plug the cape onto your BeagleBone!
Socketed Parts
SHUNT
S201 S202 S203 S204 S205 S206 S207 S208 S209 S210 S211 S212 S213 S214 S215 S216 S217 S218 S301 S501
Adjust the populated shunts as required for your desired micro-step setting.
If you have a physical ESTOP switch, connect it to the ESTOP header instead of using the shunt.
Fuses
10A
F201 F402
15A
F401
Pololu
U201 U202 U203 U204 U205 U206
These must be placed with pin 1 aligned with the heavy silkscreen rectangle indicating pin 1 on the PCB, and be careful you do not plug the modules in "off by one", or shifted in the socket. There are heavy silkscreen lines on PCB indicating the "break" between modules.
Complete
Assembly is now complete, hopefully your board looks something like this one (the Pololu modules are intentionally not shown so the parts underneath them are visible).
Setup and Testing
The EEPROM needs to be programmed with appropriate data, and the various features of the board need to be tested for proper functionality.
Example EEPROM data is located in github along with the PCB design files, but currently no programming or production test code is available. An unprogrammed EEPROM simply means you need to load the cape overlay manually, which is already done by the example configurations available with Machinekit.
Stay tuned.
