CRAMPS2.1
Release status: Experimental
Description | Cape-RAMPS for BeagleBone
License | GPL
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | KiCAD
External Link |
- 1 Summary
- 2 Safety
- 3 ECOs
- 4 Assembly
- 4.1 Required Tools
- 4.2 Cape Assembly
- 4.2.1 Surface Mount Parts
- 4.2.1.1 10 uF 10V 0805 Capacitor
- 4.2.1.2 100n 16V 0603 Capacitor
- 4.2.1.3 10u 6.3V 0603 Capacitor
- 4.2.1.4 100u 35V Electrolytic Capacitor
- 4.2.1.5 None
- 4.2.1.6 SS14 40V 1A Schottky Diode
- 4.2.1.7 Green 0603 LED
- 4.2.1.8 Red 0603 LED
- 4.2.1.9 2N7002K FET
- 4.2.1.10 DMN2075U FET
- 4.2.1.11 220R 0603 Resistor
- 4.2.1.12 330R 0603 Resistor
- 4.2.1.13 2K0 1% 0603 Resistor
- 4.2.1.14 2K7 0603 Resistor
- 4.2.1.15 4k7 0603 Resistor
- 4.2.1.16 10k 0603 Resistor
- 4.2.1.17 100k 0603 Resistor
- 4.2.1.18 74CBTD3861
- 4.2.1.19 74ACT244
- 4.2.1.20 24C256
- 4.2.2 Through Hole Parts
- 4.2.2.1 FUSE-HOLDER
- 4.2.2.2 HEADER_2
- 4.2.2.3 HEADER_2X2
- 4.2.2.4 HEADER_3X2
- 4.2.2.5 KK-2.54-2W
- 4.2.2.6 KK-2.54-4W
- 4.2.2.7 BB_EXP_CONN
- 4.2.2.8 HEADER_4X2
- 4.2.2.9 SOCKET_6_LONG
- 4.2.2.10 HEADER_6
- 4.2.2.11 HEADER_6X2
- 4.2.2.12 PT_1,5-2-3,5-H
- 4.2.2.13 PT_1,5-3-3,5-H
- 4.2.2.14 PT_2,5-2-5,0-H
- 4.2.2.15 IRLB8743PBF FET
- 4.2.2.16 10A Fuse
- 4.2.2.17 15A Fuse
- 4.2.2.18 POLOLU_SOCKET
- 4.2.2.19 SHUNT
- 4.2.2.20 Pushbutton
- 4.2.2.21 Pololu
- 4.2.3 Complete
- 5 Setup and Testing
Summary
Version 2.1 of the CRAMPS board is a mixed surface-mount and through-hole design. The fine-pitch SMT parts from version 1.0 have been removed, so all parts are now large pitch or through-hole, and are relatively easy to hand solder.
Safety
The CRAMPS board is designed to handle power levels capable of causing a fire. Be very careful with the initial board checkout, ideally using a power supply protected from short circuit and overload. Never operate your board unattended, and make sure all connected parts subject to heating (including the wires and connectors!) are far away from any potentially combustible material. Always use the proper fuses, and insure your smoke detector is working properly.
ECOs
Not yet
Assembly
Required Tools
- You must have
- Solder iron, solder wire, good tweezers
- You really need
- Solder wick, solder sucker, flux pen
- Optional methods use
- Solder paste, hot plate or oven
Cape Assembly
Soldering the CRAMPS board includes both surface mount and through hole soldering.
The surface mount can be done a few ways. To hand solder, start by putting a small amount of solder on one pad. If you have flux, coat the soldered pad. Use the tweezers to hold the component down in position and heat the solder to tack the component into place (make sure the entire solder blob flows so you don't get a cold solder joint). Then solder the other pads. Also popular is using solder paste for pad by pad soldering, Oven Reflow (need link), and HotplateReflowTechnique
Solder the SMT components first, starting with the fine pitch parts then working through the parts from shortest to tallest. Then solder the through-hole parts on top of the board. Finally solder the pin headers on the bottom of the board.
Surface Mount Parts
- C301 C302 C303 C501
- These can be placed in any orientation.
- C301 C302 C501 C502 C503 C504 C505
- C506 C507 C508 C509
- C201 C202 C203 C204 C205 C206 C401
None
- C402 C403 C404 C405 C406 C407
- D401 D402 D403 D404 D405 D406
Green 0603 LED
- LD101 LD102 LD301
Red 0603 LED
- LD302 LD401 LD402 LD403 LD404 LD405 LD406
2N7002K FET
- Q101 Q301 Q302 Q303 Q304
DMN2075U FET
- Q404 Q406
220R 0603 Resistor
- R305 R401 R403 R405 R407 R409 R411
330R 0603 Resistor
- R101 R102 R303
- R511 R512 R513 R514
2K7 0603 Resistor
- R302 R402 R404 R406 R408 R410 R412
4k7 0603 Resistor
- R304 R306 R307 R314 R515 R516 R517 R518
10k 0603 Resistor
- R301 R308 R309 R310 R311 R312 R313 R315 R316 R501 R502 R503 R504 R505 R506 R507 R508 R509 R510
100k 0603 Resistor
- R201 R202 R203 R204 R205 R206
74CBTD3861
- U501
74ACT244
- U302
24C256
- U301
Through Hole Parts
FUSE-HOLDER
- FH201 FH401 FH402
HEADER_2
- JP501 P102 P103 P301
HEADER_2X2
- JP301
HEADER_3X2
- JP201 JP202 JP203 JP204 JP205 JP206 P304
KK-2.54-2W
- P302 P407 P409
KK-2.54-4W
- P202 P203 P204 P205 P206 P207
BB_EXP_CONN
- P8 P9
HEADER_4X2
- P303 P503 P504
SOCKET_6_LONG
- P101
HEADER_6
- P305 P501
HEADER_6X2
- P502
PT_1,5-2-3,5-H
- P405 P406 P408
PT_1,5-3-3,5-H
- P404
PT_2,5-2-5,0-H
- P201 P401 P402 P403
IRLB8743PBF FET
- Q401 Q402 Q403 Q405
10A Fuse
- F201 F402
15A Fuse
- F401
POLOLU_SOCKET
- P208 P209 P210 P211
SHUNT
- S201 S202 S203 S204 S205 S206 S207 S208 S209 S210 S211 S212 S213 S214 S215 S216 S217 S218 S301 S501
Pushbutton
- SW101 SW102
Pololu
- U201 U202 U203 U204 U205 U206
Complete
Assembly is now complete, hopefully your board looks something like this one.
Setup and Testing
The EEPROM needs to be programmed with appropriate data, and the various features of the board need to be tested for proper functionality.
Currently, no programming or production test code is available, but there are plans to write some.
Stay tuned.
