Build a reprap
Revision as of 13:00, 21 October 2008 by Ronanwarrior (talk | contribs) (Addded bit about the differnt build option and tried to mention pro and cons of each so that Newbies can decide now and not half way thru building.)
This page has not been checked and may well not be accurate
Build a RepRap
There are multiple ways to build a RepRap or RepStrap; the method selected for these instructions has been chosen to minimize skills and tools needed. If you wish to explore other options click Build a RepRap-Advanced
The Classic RepRap Design is "Darwin" pictured on the right. There are very full and accurate building instructions in Make Your Own RepRap.
The RepRap was carefully designed to use only parts that can be made on a RepRap and other cheap parts that you can get anywere. It was also designed to require few skills to assemble. The one snag is you have to find someone to supply you with the parts that must be made on a RepRap
RepStrap Darwin Clones are reprap designs which are fairly accurately copies of the darwin design but the RepRapped parts are replaced by parts created some other way, Perhaps moulded plastic or laser cut acrylic or plywood. Generally parts of one of these machines are interchangeable with RepRapped Darwin parts. Here are some Parts Suppliers.
Other RepStraps, these are 3D printers capable of making RepRap (Darwin) parts but are not structuraly similar to Darwin. These machines may vary a lot but may be separated into two kinds. Those like Darwin in which the extruder (print head) is moved in the x and y directions and the work is slowly lowered as the print progresses and others where the work is moved in the x and y directions under a stationary head which gradually moves upwards as the print progresses. Here are some references to various RepStrap Machines.
If this is you first reprap that your are building here is a basic guide of which build option you should choose.
  • If you have a friend near by that can print out the reprap part on thier reprap or some other 3D printer. Choose the Classic Darwin
  • If you don't have access to 3d printer you have 3 options.
    • You can build a Classic Darwin but this mean you will have to use a commercial service to print out part for you and it can easily cost over $1000 for just those parts, depending on what deals you can get. This option is probably the most expensive option.
    • You can build a Restrap Darwin Clone. This mean you can either by a lasercut acrylic kit from Bits from Bytes or make some part you self by machining them. This option is becoming the more common option especially because soon you will be able to by a lasercut kit from Ponko which has offices in the US. This is also usaly cheaper than the first option.
    • The third option is to build non-clone Restrap that does not have the same frame as a Darwin, such as McWire which use pipes for the frame. This option is usually the cheapest, but each Restrap has it own weaknesses. The good thing is that when complete they can print out parts so that you can build a Classic Darwin. The electronics are compatible with Darwin so you only have to buy them once.
Overview
A RepRap or RepStrap (A RepRap can build itself, a RepStrap can build something that can build itself) can be divided into several key areas:
  • Object creation Software
  • System control Software
  • Thermoplastic extruder
  • Positioning system
  • The electronics to control the positioning system
Object Creation Software
Art of Illusion is currently the software most recommended for designing objects to be printed. It's not a CAD package but it is easy to use. The software allows you to create and manipulate 3D shapes. You can store these shapes in STL file format. STL files are object files that are used in Rapid Prototyping. These STL files can be printed off into real 3D objects using your 3D printer (RepRap).
The software is free (GNU GPL version 2) and it is available for Mac OS X, Windows and Linux. If you want to try it out without installing it's available bundled in the Linux distribution liveCD with the rest of the hosted software for the RepRap project.
RepRap is controlled via USB or an RS232 interface. You may find a description of download from RepRap Host Software.
There is a RepRap variant which allows you to print an object from a file saved onto a SD card.
Thermoplast extruder
There three different extruders all of which in the end perform the same function. There is the "official" extruder that can be made my another RepRap. Then there are the kits which are mass produced so that it is easier to start printing your first parts. Both kits are designed to be interchangeable with official extruder.
  • RepRapable Thermoplast Extuder
    Can be made either by another RepRap or commercial rapid prototyper. These are not the only way the parts can be made but are the easiest. Some builder have made them from machining aluminum or plastic. Other by making molds and casting from resin. This is only for the main pieces of the extruder. The drive screw and other mechanic must be bought or machined.
  • Kit from Bits from Bytes (laser cut acrylic)
    A there is an extruder kit currently available from Bits from Bytes who are based in the UK. The kit is part of the silver or gold kits and so doesn't need ordering separately unless you want a spare. Assembly instructions are available on the bits from bytes website in the 'Assembly Instructions' area:
    Bits from Bytes Extruder Assembly instructions
    Bits from Bytes Extruder 3d Model - the model requires a recent copy of Adobe Acrobat.
    There are also videos of the construction process, in the 'Tutorials' section of the website.
    Bits from Bytes Heater Barrel Assembly
    Bits from Bytes Extruder Drive Assembly
  • Kit from Ponoko (laser cut plywood)
    A kit will also shortly be available via Ponoko who have offices in the US.
Positioning system
Kits are available from Bits from Bytes, either the FULL Mechanical Kit - Silver or Gold contain all the components necessary to build a positioning system and extruder. Assembly instructions are available on the bits from bytes website in the 'Assembly Instructions' area:
Bits from Bytes Assembly Instructions
No pre-assembled option is currently available for the electronics and so you, or someone you know, will need to solder the components to the board.
The RepRap Research Foundation produces kits for the electronic components. The Complete Arduino Electronics Kit when ordered with the optional Aurduino and usb cable contains all the electronics, in component form, provides everything required to control the positioning system. The main RepRap site contains guides to constructing each of the boards the kit contains:
motor controller
shopping list
The following list contains all the components necessary to build a RepStrap and enough plastic to print a RepRap. Some handtools are required for assembly, but the only power tool used is a soldering iron.
Extruder and Positioning System
Bits from Bytes - FULL Mechanical Kit - Silver or Gold
Ponoko - coming soon
(only one required)
Electronics
RRRF Complete Arduino Electronics Kit, Arduino Diecimilia, USB cable
Plastic
The extruders all use 3mm diameter plastic filament/wire. ABS is the recommended plastic for its combination of strength, availability and dimensional stability. Suitable plastic is available from RRRF in 5lb reels. It is also available by request from plasticweldingrod.com.
Total
Shipping and tax vary by country of order but $1000 total is a reasonable approximation.
