Buckrap Hot End Bow
Revision as of 18:03, 9 November 2010 by Marten (talk | contribs) (Step 4)
Buckrap's Hot End
Here is a simple design Hot End.
200x
Parts
200x
Totaal costs are (under 15 euro's):
  • PTFE tube 6mm (ext) 30-50 cm
  • bras nozzle 0.5mm extruder and M6
  • M6 nut
  • M6 brassend / coupling nut (photo)
  • Nicrome wire
  • thermistor
  • Perforated assembly tape 6mm (In the right-down corner of the parts picture)
  • kapton tape 5mm (and optionally 10 mm)
  • Cord End Terminals 1mm
  • wire
Tools
  • pliers
  • wirecutter
  • crimping tool for Cord End Terminals
  • scissors
  • 10 mm key (M6 nut)
  • multimeter
Step 1
200x
  • first push the M6 nut on tube and use the key turn it about 2 cm on tube. Then pull back the nut and remove it.
  • turn the tube into to connector
  • turn the brass into the connector
Step 2
200x
  • tape the connector and the brass
  • place the NiCrome wire (note to self 28,3 cm and check for 6 ohm)
  • tape the NiCrome in place
Step 3
200x
  • isolate the termistor wires with kapton tape
Step 4
200x
Take attention here
  • strip 2 writes over 7 cm
  • strip 2 writes over 4 cm
  • crimp the long wires to the Nicrome
  • crimp the short wires to the termistor
  • isolate all wires separate
Step 5
200x
  • wrap them together
  • wrap them to the connector
  • isolate to top of the connector (temp isolating)
Step 6
200x
  • Use Perforated assembly tape to mount (MakerBot example here)
