Buckrap Hot End Bow
Revision as of 17:15, 9 November 2010 by Marten (talk | contribs) (Step 2)
Buckrap's Hot End
Here is a simple design Hot End.
320x
Parts
320x
Totaal costs are (under 15 euro's):
  • ftge tube 6mm (ext)
  • bras nozzle 0.5mm extruder and M6
  • M6 nut
  • M6 brassend / coupling nut (photo)
  • NiCrome wire
  • thermistor
  • Perforated assembly tape 6mm
  • kapton tape 5mm (and optionally 10 mm)
  • Cord End Terminals 1mm
  • wire
Tools
  • plier
  • wirecutter
  • crimping tool for Cord End Terminals
  • sissors
  • 10 mm key (M6 nut)
  • multy meter
Step 1
320x
  • first push the M6 nut on tube and use the key turn it about 2 cm on tube. Then pull back the nut and remove it.
  • turn the tube into to connector
  • turn the brass into the connector
Step 2
320x
  • tape the connector and the brass
  • place the NiCrome wire (note to self 28,3 cm and check for 6 ohm)
  • tape the NiCrome in place
Step 3
320x
Step 4
320x
