BrundleFab
Revision as of 23:09, 18 August 2015 by Ezrec (talk | contribs) (Introduction)
BrundleFab
Release status: unknown
BrundleFab - an inkjet based sugar printer
Introduction
'BrundleFab' is an attempt to build a 3D powder bed printer, using sugar as the working medium, and with output as a food quality edible.
The name comes from the 1986 movie 'The Fly': "Do you normally take coffee with your sugar?"
Current "state of the project" is that I can successfully extrude multiple powder layers, and deposit binder at 96DPI.
Printing a 140mmx140mmx24mm (1mm layers) object takes approx 3 hours with my current settings.
The pigment-selective thermal fusion is working, but I need replace the halogen lamp fixture with a metal version.
I continue to work on tuning the fuser and powder/binder recipes for better part adhesion.
Youtube video of first calibration layer: <videoflash type="youtube">zHy0NdR5VD0</videoflash>
Video of multi-pass thermal fusion: <videoflash type="youtube">p7PbIBS-NHo</videoflash>
Theory of Operation
The BrundleFab is designed for experimenting with thermally fused powders - where a powder is colored to be IR absorptive, and heat applied to sinter the powder together in the colored regions.
With the fuser off, it can be used with conventional powder + binder recipes, but for that I would recommend an existing non-prototype machine, such as the YTec Plan B.
BrundleFab uses a single layer head for all layer operations - recoat, ink deposition, and fusing.
Here's some terrible ASCII Art explaining the layer head:
           ___
          /   T
       __/_ F _\__________oH
    ||/ <-R          S-> \ H                                      ||
    ||    Feed Bin       ||    Part Bin       ||    Waste Bin     ||
    ||       E :: Axis   ||       Z :: Axis   ||                  ||
  Key:
    || - Wall of the powder chambers
    -- - Top of the feed/part powder layers
    == - Top of the feed/part pistons
    F  - Thermal fuser (halogen bulb)
    T  - Thermal sensor
    R  - Recoating blade
    S  - Powder sealing blade
    H  - Ink head
    o  - Ink head rail
A BrundleFab layer is constructed as follows:
  1. The layer head begins at the minimum X position, positioning the repowder blade at the start of the Feed Bin
  2. The Feed Bin raises by one layer width, the Part Bin lowers by one layer width
  3. The layer head advances in X until the the fuser (F) is at the start at the start of Part Bin.
  4. The fuser is enabled, and brought up to temperature.
  5. The layer head advances in X, depositing fresh powder onto the newly fused layer, until the the fuser (F) is at the start of the Waste Bin
  6. The fuser is disabled.
  7. The layer head advances in X, until the repowder blade (R) is at the start of the Waste Bin
  8. The Part Bin (Z) and the Feed Bin (E) both drop by 1mm.
    • This is needed so that the repowder blade will not disturb the existing powder layer during the inking pass.
  9. The layer head retracts in X until the ink head (H) is at the end of the Part Bin.
  10. The ink deposition phase then begins, depositing ink on the fresh powder layer, as the layer head retracts in X.
  11. The layer head is fully retraced.
    • This will position the repowder blade (R) at the start of the powder feed bin.
  12. The Feed Bin raises by 1mm, the Part Bin raises by 1mm
Repeat steps 1 - 12 for all layers. A final 'no ink' layer is inserted after the last printed layer to ensure compete fusing.
Sources
My sources are available on GitHub:
Electronics
Power
I'm using a SATA connector from a PC power supply, and have soldered on 0.100" pins for easy interfacing.
Arduino
I using steppers for my X, Z, and E axes, and the DC Motor + Encoder for the Y (printhead) axis.
There are two ATmega devices - an ATMega2560 controls the UI, GCode, and X/Z/E axes. A ATmega328 controls the printhead and Y axis, and is directly mounted on the inkbar carriage.
They are connected by a 115200n81 serial link (5v logic, not RS232).
AdaFruit 1.8" TFT Shield + Joystick
Adafruit Motor Shield v2
The Adafruit Motor Shield v2 appears to be inadequate for accurate PID control of DC motors - the I2C bus latency to the PWM controller is too high for my PID tuning skills.
Adafruit Motor Shield v1
However, the Adafruit Motor Shield v1 has the Arduino PWMs directly connected to the motor drivers - I have been able to get pretty accurate PID control of my DC motors with this shield.
Although it is no longer sold by Adafruit, the design has been duplicated by a number of 2rd party manufacturers, so it's still easy to come by.
Adafruit ST7735 UI/Visualizer
I'm using the Adafruit ST7735 as my user interface and SD card holder.
The visualization software in this video can be easily added to any RepRap firmware, see the 'Visualize.h' class in the BrundleFab-firmware repo, and the 'GCode.cpp' 'ENABLE_UI' sections for where to integrate.
<videoflash type="youtube">TawT_PwRFz4</videoflash>
Ink Head
InkShield
I'm using Nicholas C Lewis' Inkshield device to control a HP C6602 cartridge.
HP F4480
I am using a pile of trashed HP F4480 DeskJet printers as a source of motors, gears, and encoders.
Here are some information I have discovered about the internals of this printer:
Rotary optical encoder board
This board monitors the 1200 DPI optical encoder disk attached to the main paper handling roller in the printer.
It uses quadrature encoding, and can monitor both forward and reverse direction.
I am using the 'Encoder' library from the [1] Arduino library collection.
Pin 1 is the kerf on the CPU board connection
Pin Function
4 Output A
3 Vcc 3.3v
2 Output B
1 Gnd
Printhead Controller
The HP F4480 printhead carriage monitors a 1200 DPI optical encoder strip, which is the feedback to the carriage motor, and manages the shift registers to the matrix printhead.
These electronics will not be used by BrundleFab, and are bypassed - the IR sensor for the optical encoder is directly wired to the ATmega323.
DC Motor/Encoder Interfaces
I scavenged the connectors from the HP printers and build some extension cabling for the X and Y axis controls.
Wire colorcode key:
Color Function
White/Orange Ground
Orange/Write 3.3v
White/Blue Encoder A
Blue/White Encoder B
White/Purple Motor -
Purple/White Motor +
DC Motors
Although the printhead DC motor was designed to be driven at 30v, it operates fine at 12v, PWM at 50% for nominal operation.
Fuser
The Fuser assembly consists of a high-intensity halogen bulb (from a HP laser printer) with an aluminum foil reflector.
Temperature monitoring is very indirect (thermistor lightly pressing against the aluminum heat shield), and is done by using a 250K/Beta 4066 thermistor (salvaged from the same HP laser printer), using a 1.8K resistor for voltage dividing.
Currently, thermal monitoring is only used to prevent overheating of the fuser housing (exceeding 190C will melt the plastic).
After the inking pass, the intent is to run the fuser over the inked area, and lightly caramelize the colored section.
Or, at the very least, dry the ink out to prevent excessive saturation.
Powderbed
Overall Design
From the front of the printer, the X axis is from left (negative X - the feed bin area) to right (positive X - the part bin area).
Past the part bin, there is a 'cleaning' chute area where excess powder will fall during the print cycle.
The conceptual design is for the powder wipe to immediately follow the print head, and the print head never executes a negative X movement until the Z slice is complete.
The X axis is controlled by a stepper motor, which pulls on a braided (non-stretching) fishing line attached to the Y axis trolley.
The Y axis is controlled by a DC motor + linear encoder, mounted on the inkjet carriage of the HP4480 printer. As I have multiple HP4480s, I will use a mounting system that will allow me to easily interchange the inject carriage, so as to replace the Y axis movement in case of failure.
The Z-part and E-feed axes will be driven by two NEMA17 steppers, driving a 40cm trapezoidal (Tr8x4) drive screw. See the Piston section for details.
Frame
The powder bed frame is constructed from recycled MDF material (recycled from various IKEA flat-pack furniture pieces that outlived their life span).
MDF has the advantage of being cheap, readily available, and easy to cut accurately with home shop tools.
Although I chose melanine-covered MDF for this prototype printer, any smooth-surfaced stiff material should work for a powderbed frame. A smaller version using acrylic, or a larger version using 4mm aluminum sheet would be feasible.
The OpenSCAD files are parameterized to allow for easy adaptation to different target build volumes, and material widths. (See the hardware sources above)
Piston
Currently I only have NEMA 17 motors, so I have built a piston insert for half of the frame. The left side of the frame will be unused for this prototype, until I get larger stepper.
Instead of ripping the frame apart, I came up with the idea of using an insert - a divider with a base (making an inverted "T" shape) and the piston plates are on each side of the T.
The insert uses two NEMA 17 motors with integral 40cm Tr8x4 screws, 4 pieces of MDF, and some scrap sheet metal a motor mounts. The endstops, although in the same physical location, are configured differently for each axis.
For the Z axis, which starts at the top of the piston chamber and moves down, the endstop is for Maximum Z.
For the E axis, which starts at the bottom of the piston chamber and moves up, the endstop is for Minimum E.
This piston design jams easily on even small amounts of powder grit if you attempt a precision fit - varying amounts of humidity will cause swelling in the MDF, and a tight fit will easily become a jammed piston.
To solve this issue, my piston is undersized by approx 1mm on all sides, and a slightly oversized vinyl fabric is glued on top of the piston head. The vinyl fabric creates an adequate seal, even with the undersized piston head.
Print Media Material Testing
These early tests were done with 'hand printing' an object (manual layer deposition, and using a needle bottle to apply large binder droplets).
Granulated Sugar + Water
Process
  1. Lay down 10mm of granulated sugar
  2. Sift a layer of 1mm of granulated sugar
  3. Apply 1mm droplets of (colored) water to the granulated sugar via a needle bottle (unknown tip size)
  4. Go to 2. until part build volume is complete
  5. Lay down 10mm of granulated sugar
  6. Heat at 120C (250F) in oven for 1 hour
  7. Let cool
  8. Remove from build container, and remove excess sugar
Results
The resulting object was stiff, but easily crumbled. Water dispersion through the granulated sugar had an approx 5mm radius, and substantially filled in the interior of the part (wireframe cube).
Analysis
  • Droplet size should be smaller
  • Either a finer granularity or pressure packing of the media should reduce the spot size of the print head
  • A food safe adhesive should be tried to increase bonding strength
    • In-powder adhesive (such as meringue powder) activated by water
    • In-suspension adhesive (such as egg whites)
Powdered Confectionery Sugar + Water
  2. Sift a layer of 2mm of granulated sugar, and pack down to 1mm.
  3. Apply 1mm droplets of (colored) water to the powdered sugar via a needle bottle (unknown tip size)
  7. Let cool
Results
Sugar did not re-crystallize, I suspect the cornstarch at fault here.
Analysis
  • Powdered Confectionery Sugar is not suitable for printing, due to the cornstarch content.
Powdered Sugar/Meringue Powder + Alcohol/Water
  • Powder base is granulated sugar and meringue powder
  • Adhesive is alcohol and water
Procedure
  1. Lay down 10mm of powder
  2. Sift a layer of 2mm of powder, and pack down to 1mm.
  3. Apply 1mm droplets of (colored) adhesive to the powder via a needle bottle (unknown tip size)
  7. Let cool
Results
  • Sugar/Meringue powder is % by mass
  • Alcohol/Water is % by volume
Sugar Meringue Powder Water Alcohol Results
90% 10% 50% 50% Small droplet size (1mm), no capillary creep from the droplets; resulting object could be rinsed of excess powder
Analysis
  • Should be a sufficient working material, need to experiment with different ratios.
Granulated Sugar + HP C6602 Black Ink (multiple pass, no fusing)
  • Binder is HP C6602 Black Ink
Procedure
  2. Ink calibration pattern at 96DPI
  3. Repeat pattern 10 times
  4. Let sit overnight to fully dry
Results
  • The 'binder' simply colored the granulated sugar, as expected.
  • A very small amount of binding was observed, but not enough to allow even light handling of the layer
Granulated Sugar + HP C6602 Black Ink (1mm layer, 4 sprays per dot, fusing at 68C)
  • Fuser set to make a 1500mm/minute pass
    • Unfortunately, post-recoat..
  • Ambient sugar temperature 33C, post-fuser temperature 68C
Procedure
  2. Ink calibration pattern at 96DPI, 4 sprays per dot
  3. Apply powder recoat of 1mm
  4. Heat with fuser at 1500mm/minute - black temperature recorded as 68C.
  5. Repeat from (2) for 24 layers
Results
    • This was primarily a 'conservative baseline' for the fuser
  • Some binding was observed, enough to allow partial vacuum depowdering
  • Object could not be handled
Analysis
  • A higher fusing temperature is needed for caramelization of the sugar
  • Fuser should be run after inking, not after repowdering
Granulated Sugar (fuser stalled, heat shield at 190C)
  • Fuser on for 30 seconds at 190C
Procedure
  2. Turn on fuser for 30s at 190C
Results
  • This was totally by accident - fuser got stuck on return pass, and overheated an uninked powder area.
  • Nicely bound approx 1mm of granulated sugar, without ink.
  • Recoating blade was hot - may be a concern if it caramelizes unwanted areas.
Analysis
  • If fuser is run at a high temperature, a heat break may be needed between the fuser and the recoat blade.
Granulated Sugar (fuser at 250mm/minute, heat shield at 300C)
  • Fuser on, cutout temperature at 300C at the heat shield
  • Fuser pass rate is 250mm/minute
Procedure
  1. Lay down 1mm of granulated sugar
  2. Ink layer
  3. Turn on fuser (300C 'safety cutout' at heat shield)
  4. Pass fuser over sugar at 250mm/minute
Results
  • Inked area has variable quality of fusion
    • First few cm fused are very lightly fused
    • Approx 5cm of correctly fused inked area, unfused plain powder
    • Last few cm have plain powder fused, inked area has pooling effects
  • Pooled areas tend to expand in the Z direction, and are scraped off during recoat
  • Interior uninked areas lightly fused, difficult to depowder
Analysis
  • Fuser needs to pass at a variable rate - slower during warm up, then faster once target brightness achieved.
Powdered Sugar (fuser at 250mm/minute, heat shield at 300C)
  • Powder base is powdered sugar
Procedure
  1. Lay down 1mm of powdered sugar
  2. Ink layer
  4. Pass fuser over sugar at 200mm/minute for 6s (warm-up), then 300mm/minute for the rest of the pass
Results
  • Powdered sugar seems to require more energy to fuse than granulated
  • 1mm thick layer with 6 sprays per dot - not enough ink penetration for intra-layer binding
  • Extruder hit maximum limit - last layer had multiple fuser passes
    • Last layer had good fusing.
Analysis
  • Fuser needs to apply more energy for powdered sugar
    • Slower single pass?
    • Multiple passes?
    • Separate recoat and fusing passes?
