Brett's manual install
Revision as of 00:25, 13 August 2011 by Bsutton (talk | contribs)
Platform Ubunutu 11.04 Open Java SDK 6.0
Directory structure
~/reprap/jar
~/reprap/lib
~/reprap/lib-x86_64
~/reprap/reprap
Directory contents of: ~/reprap/jar
reprap.jar
Directory contents of: ~/reprap/lib
j3dcore.jar
j3d-org-java3d-all.jar
j3dutils.jar
reprap.ico
reprap.properties.dist
reprap-wv.stl
RXTXcomm.jar
swing-layout-1.0.4.jar
vecmath.jar
Directory contents of: ~/reprap/lib-x86_64
This is the directory for the shared libraries. Unlike the java jar's these are specific to the CPU you are running.
libgluegen-rt.so
libjogl_awt.so
libjogl_cg.so
libjogl.so
Contents of reprap (this is a script)
#!/bin/bash
# reprap-host -- runs RepRap Java host with an appropriate classpath
# Usage: ./reprap
# or
# ./reprap <installdir>
# where <installdir> is the directory path where reprap host has been installed.
# check we are running the correct version of java
java -version 2>&1 | awk 'NR==1 {if (index($3, "1.6") >0) exit 0 ;exit 1}'
if [ "$?" -ne "0" ]; then
  echo "Sorry you need to be running Java 6 for reprap to run"
  exit 1
fi
# Amount of RAM to allow Java VM to use
# You may need to increase this to load in really large jobs.
REPRAP_RAM_SIZE=1024M
REPRAP_DIR=`dirname $0`       # reprap.jar, jni libs and stl file
cd $REPRAP_DIR
MACHINE=`uname -m`
# put the directory with the native RXTX and j3d libs in the library path
LD_LIBRARY_PATH=/usr/lib/jni:`pwd`/lib-${MACHINE}:${LD_LIBRARY_PATH}
export LD_LIBRARY_PATH
CLASSPATH=./jar/reprap.jar
# we are using java 6 so a wild card will pick all of the jars in the directory
CLASSPATH=$CLASSPATH:./lib/*
# the .stl file must be in a directory which is on the the classpath but its not a jar so the wild card won't work
# invoke the code
java -cp $CLASSPATH -Xmx$REPRAP_RAM_SIZE org.reprap.Main
