Board safety
Revision as of 18:51, 23 December 2015 by PRZ (talk | contribs) (See also: link to safety page)
Board/Firmware Safety of a FFF printer
An important part of 3D printer safety is handled by its board and firmware combination
The purpose of this page is to evaluate the implementation of safeties. Other safeties shall be considered for 3D printers, but they are outside the scope of this page.
Codes used
The following table could be based on the analysis of the software or on tests
Results :
  • 'X' if analysis confirm compliance, 'N' if not, 'NP' if partial (e.g. not all loops)
  • 'I' indicates that the safety could be implemented but depends from hardware choices, e.g. killing the power supply depends from installation of a relay
  • 'T' if safety physically tested ok, 'F' if physical failed completely 'FP' if failed partially
Tests and analysis shall be carried on all loops, a partial failure or non compliance shall be explained in notes
If analysis is not possible (closed source software) and test impossible to do, e.g. a watchdog in the processor, test shall be considered failed
  • '-' indicates that it is not applicable
  • a value could follow the result tag (e.g. delay to stop X2000 or T1850)
  • a note reference could follow the result tag (e.g. NP (12))
  • '?' for unknown answer
One column is for a combination of hardware and firmware, so there could be multiple columns for one board/one firmware
Implementation
Board/firmware safety
Firmware myfirm
Firmware revision 0.0
Board type myBoard
Board revision 0.9
1 Thermistor shorted/disconnected warning at startup – all heaters – define warning type
2 Thermistor shorted/disconnected at startup prevent heating – all heaters
3 Thermistor shorted/disconnected during run warning – all heaters – define warning
4 Thermistor shorted/disconnected during run stop heating – all heaters
5 Temperature rise too slow stop heating – all heaters
6 Temperature rise too fast stop heating – all heaters
7 Too high temperature stop heating – all heaters
8 Too low temperature stop heating (untrustable sensor) – all heaters
9 Unstable temperature stop heating – all heaters
10 Filter thermal sensor noise – all heaters
11 Temperature rising while heating stopped give local warning (sound) – all heaters
12 Temperature rising while heating stopped give warning on remote controller – all heaters
13 Temperature rising while heating stopped kill power – all heaters
14 Heating active while printer not running stopped after a timeout for hotends – delay in sec .
15 Heating active while printer not running stopped after a timeout for bed heater
16 Heating active while printer not running stopped after a timeout for chamber heater
17 Reset/boot stop all heating
18 Reset/boot kill power (relay command or ATX power supply deactivation)
19 Watchdog in the processor (interruption while software is freezing)
20 Watchdog external (tick on a processor pin)
21 E-stop connected on board – precise action
22 Fuse/safety on board on 3.3V – precise type and current
23 Fuse/safety on board on 5V – precise type and current
24 Fuse/safety on board for heating power voltage (12/24V) – precise type and current
25 Beep output or beeper on board
Stop heater mean the FET is in non conductive state or SSR/relay signal is down Kill power means that all heater FET are no longer electrically supplied (in case of FET failure conductive)
Watchdog [1] (firmware freeze detection)
Watchdog are delicate to implement [2] in multitasking processus [3] and they could work in one case not in another case.
To check if they are working in all cases need deep understanding of the firmware and guaranty their proper operation is not easy It is advisable that the reviewer justify his position on this particular subject In addition, if they are not physically implemented (say they are interrupt in the processor and not a pin activation) they cannot be tested
See also
References
External links
https://groups.google.com/forum/#!topic/deltabot/sC4EzK5N_qk[26-50]
http://www.fastbot3d.com/forum/t-1355891/required-heater-safety-controls
