Bill of Material Tiny Cut
Revision as of 13:06, 21 February 2013 by Marinosaurus (talk | contribs) (Created page with 'mini led de pointage 12V 12V 650nm Red beam Linear Laser Light => ebay => 3 € http://www.ebay.fr/itm/12V-650nm-Red-beam-Linear-Laser-Light-/271147084665?pt=LH_DefaultDomain_0…')
mini led de pointage 12V 12V 650nm Red beam Linear Laser Light => ebay => 3 € http://www.ebay.fr/itm/12V-650nm-Red-beam-Linear-Laser-Light-/271147084665?pt=LH_DefaultDomain_0&hash=item3f21a02b79#ht_1157wt_1031
lumière intérieur: 5M Warm White 5050 SMD Flexible LED Strip Light 300 Leds IP65 Waterproof = ebay = 12 € http://www.ebay.fr/itm/5M-500CM-Warm-White-5050-SMD-Flexible-LED-Strip-Light-300-Leds-IP65-Waterproof-/110940638477?pt=US_Car_Lighting&hash=item19d493cd0d#ht_3637wt_1031
bouton d’arret d’urgence AC 660V 10A 40mm Red Sign Emergency Stop Switch Push Button Mushroom = ebay = 4 € http://www.ebay.fr/itm/AC-660V-10A-40mm-Red-Sign-Emergency-Stop-Switch-Push-Button-Mushroom-PushButton-/390506980349?pt=AU_B_I_Electrical_Test_Equipment&hash=item5aec07a3fd#ht_1491wt_899
lunette de protection. Protection Safety Glasses Goggles for 10600nm CO2 laser CE CERTIFICATION = ebay = 30€ http://www.ebay.fr/itm/Protection-Safety-Glasses-Goggles-for-10600nm-CO2-laser-with-CE-CERTIFICATION-/320897958721?pt=LH_DefaultDomain_0&hash=item4ab7024341#ht_1372wt_1270
power suplly laser 40W Power Supply for CO2 Laser Engraving Cutting Machine 220V = ebay = 98 € http://www.ebay.fr/itm/New-High-Quality-40W-Power-Supply-for-CO2-Laser-Engraving-Cutting-Machine-220V-/330792470660?pt=PCA_UPS&hash=item4d04c48884#ht_1759wt_1270
tête de gravure CO2 10600nm Laser Head w/ Mirrors & Focus Focal Lens Integrative Mounts = ebay = 130€ http://www.ebay.fr/itm/A-set-of-CO2-10600nm-Laser-Head-w-Mirrors-Focus-Focal-Lens-Integrative-Mounts-/180872049290?pt=LH_DefaultDomain_0&hash=item2a1cd0728a#ht_1702wt_1031
Water cooling pompe 12V DC Liquid Water Cooled Pump & Tank f/ CO2 Laser cool system = ebay = 18€ http://www.ebay.fr/itm/12V-DC-Liquid-Water-Cooled-Pump-Tank-f-pc-Computer-CPU-CO2-Laser-cool-system-/170929162068?pt=US_Water_Cooling&hash=item27cc2c0754#ht_3310wt_1031
autre pompe 1.2A 14W 12V DC pump water cooler motors speed line No Brushless = ebay = 14€
http://www.ebay.fr/itm/1-2A-14W-12V-DC-pump-water-cooler-motors-speed-line-No-Brushless-3-pin-plug-F-PC-/170929162135?pt=US_Video_Card_GPU_Cooling&hash=item27cc2c0797#ht_3733wt_1031
tube flexible 8mm 5/16" 1 MTR CLEAR PVC FLEXIBLE WATER PIPE = ebay = 5,5€
http://www.ebay.fr/itm/8mm-5-16-1-MTR-CLEAR-PVC-FLEXIBLE-AQUARIUM-AIR-WATER-HOSE-PIPE-POND-TUBING-TUBE-/380416380174?pt=UK_HomeGarden_Garden_PondsWaterFeatures_UK&hash=item5892954d0e#ht_4450wt_1031
Mini pompe New Mini Water Priming Pump DC 3-12V 9V RS-360SH Spray Motor = ebay = 3€ http://www.ebay.fr/itm/New-Mini-Water-Priming-Pump-DC-3-12V-9V-RS-360SH-Spray-Motor-Pisciculture-/170902508850?pt=LH_DefaultDomain_0&hash=item27ca955532#ht_1846wt_1031
Super filtre 37cm par 37cm = 2000€
