Betzbot
Release status: experimental
Description | Gada Prize Entry
License | |
Author | |
Contributors | |
Based-on | [[]]
Categories | |
CAD Models | |
External Link |
Name
The Betzbot is named after Vladimir Betz, a Russian anatomist and histologist famous for the discovery of giant pyramidal neurons of primary motor cortex.
Design Criteria
Primary Design Criteria
- Print with three three different materials*
- Print electrically conductive material
- Print Electronic Circuit Boards*
- Print Bed usable through 20 print cycles*
- Total cost, not including Print Bed, not exceeding $200*
- Not less than 90% of the volume of the printer must be printed*
- Build volume of at least 300x300x100mm
- Full part set printable in under 10 days unassisted save cleaning one head jam
- Print untethered from PC
- Consume no more than 60 watts*
- *Clarification Needed
T-slot Construction
Betzbot is designed to be built using T-slot profile beams gained through printing or die extrusion. The variety of T-slot accessories available as well as it's availability in the more expensive, more rigid, aluminum will allow for different configurations to be tested and lend easy to modification and personalization. The profile in design for Betzbot is currently available on thingiverse at thing:9013.
Axis & Frame
Many different configurations exits, each with their own set of advantages and disadvantages.
Example | X-Axis | Y-Axis | Z-Axis | Pro | Con |
Mendel | Toolhead | Bed | Carries X | ||
Thing-O-Matic | Bed | Carries X | Toolhead | ||
Ultimaker | Toolhead, Y | Toolhead, X | Bed | ||
MicRo | Carries Z | Carries X | Toolhead |
The limiting design constraint for this aspect of the machine is the rigid frame and precise axis constraint. It is likely several configurations will be designed, built and tested to determine which is most suitable.
Smooth Rail, Rack & Pinion
By printing on the diagonal against a smooth flat surface it is possible to print a rigid, smooth rail up to <math>\sqrt{2} </math> of your bed length. Betzbot uses a printed smooth rail for axis constraint. The flatness and smoothness are determined by the properties of the bed, since the surface used is the one that was printed against the bed. The current design uses a smooth rail attached to plastic 20mm T-slot.
The following instructions presume equal bed width and length. Units are in mm.
- Extrude the rail so that the length is almost but lest than (1.41*Bed length - 25)
- Disable Outline in your slicing software
- Start printing a single layer and adjust the models location to fit snuggly against your printable corners
- Lay down 20mm wide or greater kapton tape along the diagonal where your model will be printed
- Print and allow to cool - Do NOT remove from bed
- While on the print bed, bolt the rail to a 20mm T-slot extrusion
- Using the small gaps along the sides of the print, gently pop the rail of the print bed
Toolheads
- 2 Peristaltic Paste Extruders
- 2 Thermoplastic Extruders
