Belts and Pulleys
Revision as of 00:47, 21 May 2013 by Robotdigg (talk | contribs) (Pulleys)
See also Choosing_Belts_and_Pulleys
Belts
Supplier From Type available Pitch Width Length Material Approximate Cost Additional notes
Charlie's 3D Technologies Belgium MXL and GT2 - - - - See my site for prices -
RobotDigg China GT2. Can machine MXL, T2.5 for you MOQ 200pcs 2 mm 6mm, 6.35mm or 9mm 20M or 50M per roll Neoprene Rubber, Fiberglass Reinforced 1.8USD/M MOQ 50M
BBMan US Imperial/Metric
Belting Online UK many
Econobelt US many
Eke China many
Indiamart India many
KainaBelt China many
Makemendel India T2.5 2,5 mm 7 mm 700 mm - 5,49 $ -
Megadyne Italy many
Misumi multiple
Paoparts France T2.5
T5
2,5mm
5mm
5mm - PU 7,90 € / m
5,90 € / m
PolyBelt US T2.5
T5
5 mm 6 mm - polyurethane + steel 18 $ / m
3 $ / m
RepRapWorld Netherlands T2.5
T5
2,5 mm
5 mm
5 mm
5 mm
1 m neoprene
4,17 € / m -
Royal supply US GT2 2 mm 6 mm 1164 mm fiberglass / nylon / neoprene 5,48 $ -
SDP-SI US Imperial/Metric
TechPaladin US GT2 2 mm 5 mm 1160 mm neoprene 8,50 $ -
Tanals France many - - - - - don't sell to individuals
There is also some on ebay.
  • beside GT2 belts, there is also 2M that have a 2mm round pitch (like [1] and many other suppliers)
Pulleys
Supplier From Type available Pitch Tooth Size (bore, OD,...) Max belt width Material Approximate Cost Additional notes
Charlie's 3D Technologies Belgium MXL and GT2 - 15 or 20 - - - See my site for prices and info -
RobotDigg China GT2 2mm 20 5*17.5*18 mm 7mm Alu 2 $ SKYPE: robotdigg
BBMan US many
Econobelt US many
MakeMendel India T2.5 2,5 mm 16 5 mm  ? Alu 4,49 $ -
Misumi multiple
Paoparts France T2,5
T5
RepRapWorld Netherlands T5 5 mm 8 5 mm x 17 mm x 20 mm  ? Alu 4,75 € Pulley profile has play resulting in lash when reversing
Royal Supply US GT2 2 mm 18 4,7 mm 6 mm Alu cost you'll need to redrill the bore (3/16") to fit usual 5 mm motor shaft
SDP-SI US many
TechPaladin US GT2 2 mm 36 5 mm 6 mm plastic/bronze 6 $ -
Ultimachine US GT2 2 mm 20 5 mm 6 mm Alu 11 $ use two set screws
Cable
