Belts and Pulleys
See also Choosing_Belts_and_Pulleys
Belts
Supplier | From | Type available | Pitch | Width | Length | Material | Approximate Cost | Additional notes |
BBMan | US | Imperial/Metric | ||||||
Belting Online | UK | many | ||||||
Econobelt | US | many | ||||||
Eke | China | many | ||||||
Indiamart | India | many | ||||||
KainaBelt | China | many | ||||||
Makemendel | India | T2.5 | 2,5 mm | 7 mm | 700 mm | - | 5,49 $ | - |
Megadyne | Italy | many | ||||||
Misumi | multiple | |||||||
Paoparts | France | T2.5 T5 |
2,5mm 5mm |
5mm | - | PU | 7,90 € / m 5,90 € / m |
PolyBelt | US | T2.5 T5 |
5 mm | 6 mm | - | polyurethane + steel | 18 $ / m 3 $ / m |
RepRapWorld | Netherlands | T2.5 T5 |
2,5 mm 5 mm |
5 mm 5 mm |
1 m | neoprene polyurethane + steel |
4,17 € / m | - |
Royal supply | US | GT2 | 2 mm | 6 mm | 1164 mm | fiberglass / nylon / neoprene | 5,48 $ | - |
SDP-SI | US | Imperial/Metric | ||||||
TechPaladin | US | GT2 | 2 mm | 5 mm | 1160 mm | neoprene | 8,50 $ | - |
Tanals | France | many | - | - | - | - | - | don't sell to individuals |
There is also some on ebay.
- beside GT2 belts, there is also 2M that have a 2mm round pitch (like [1] and many other suppliers)
Pulleys
Supplier | From | Type available | Pitch | Tooth | Size (bore, OD,...) | Max belt width | Material | Approximate Cost | Additional notes |
Charlie's 3D Technologies | Belgium | MXL | 2.03 mm | 15 | 5.08 x 9.19 mm | ? | Alu | 4,17 € | - |
BBMan | US | many | |||||||
Belting Online | UK | many | |||||||
Econobelt | US | many | |||||||
MakeMendel | India | T2.5 | 2,5 mm | 16 | 5 mm | ? | Alu | 4,49 $ | - |
Misumi | multiple | ||||||||
Paoparts | France | T2,5 T5 | |||||||
RepRapWorld | Netherlands | T5 | 5 mm | 8 | 5 mm x 17 mm x 20 mm | ? | Alu | 4,75 € | - |
Royal Supply | US | GT2 | 2 mm | 18 | 4,7 mm | 6 mm | Alu | cost | you'll need to redrill the bore (3/16") to fit usual 5 mm motor shaft |
SDP-SI | US | many | |||||||
TechPaladin | US | GT2 | 2 mm | 36 | 5 mm | 6 mm | plastic/bronze | 6 $ | - |
Ultimachine | US | GT2 | 2 mm | 20 | 5 mm | 6 mm | Alu | 11 $ | use two set screws |
Cable
- Synchromesh
- https://sdp-si.com/eStore/PartDetail.asp?Opener=Group&PartID=5503&GroupID=312 $9.90 for 5mm bore 15 tooth gear
- https://sdp-si.com/eStore/PartDetail.asp?Opener=Group&PartID=84751&GroupID=768 $5.50 per meter
