Belts and Pulleys
Revision as of 10:14, 5 November 2013 by 3dacessorieshub (talk | contribs) (Belts)
This page has been flagged as containing duplicate material that GT2_Timing_Belt also attempts to cover.
These pages should be merged such that both pages do not attempt to cover the duplicate topics.
See also Choosing_Belts_and_Pulleys
Belts
See also GT2 Timing Belt
Supplier From Type available Pitch Width Length Material Additional notes
3D Acessories Hub India GT2 2 mm -- Rubber -
3D Printer Czar US GT2 2 mm 6 mm at your choice Neoprene, fiberglass reinforced -
3DCracker CN GT2 2 mm 6 mm 1350mm and open ended Neoprene, fiberglass reinforced -
3DMakerWorld US GT2 2 mm 6 mm 1164 mm Neoprene, fiberglass reinforced -
Charlie's 3D Technologies Belgium MXL and GT2 - - - - -
Cubic Print Germany T2.5
T5
2.5 mm
5 mm
6 mm as you wish PU + steel open belts
BBMan US Imperial/Metric
Belting Online UK GT2, MXL, T2.5, T5 2 mm 2.5 & 5mm As you wish As you wish PU & Neoprene Rubber Genuine Branded Quality Products
Easy RepRap USA Precision GT2 2 mm 6 mm 1150mm Fiberglass Reinforced GT2 Belt/Pulley Sets
eBay: Yellowvirtualsales USA Precision GT2 2 mm 6 mm Cut To Length Fiberglass Reinforced Fast Worldwide Shipping
Econobelt US many
Eke China many
Indiamart India many
Inventables US MXL - - 1 foot increments - -
KainaBelt China many
Makemendel India T2.5 2,5 mm 7 mm 700 mm - -
Megadyne Italy many
Misumi multiple
Paoparts France T2.5
T5
2,5mm
5mm
5mm - PU
PolyBelt US T2.5
T5
5 mm 6 mm - polyurethane + steel -
RepRapWorld Netherlands T2.5
T5
2,5 mm
5 mm
5 mm
5 mm
1 m neoprene
RobotDigg China GT2, MXL, T2.5 2 mm 6mm, 6.35mm or 9mm 20M or 50M per roll ,Closed-loop GT2 Neoprene Rubber, Fiberglass Reinforced. MOQ 50M
Royal supply US GT2 2 mm 6 mm 1164 mm fiberglass / nylon / neoprene -
SDP-SI US Imperial/Metric
TechPaladin US GT2 2 mm 5 mm 1160 mm neoprene -
Tanals France many - - - - don't sell to individuals
Thingibox Spain GT2 2mm 5 mm 1 m Neoprene Rubber Worldwide shipping
Vendor Loc. Product Width Pitch Length Additional notes
3D Acessories Hub IN GT2 Belt 7 mm 2.00 mm 660 mm
3DCracker CN GT2 Belt 6 mm 2.00 mm Open ended and closed-loop
3Distributed UK Prusa Kit 6 mm 2.00 mm 1000 mm
3Distributed UK Rostock/Delta Kit 6 mm 2.00 mm 1000 mm
3DMakerWorld US Belt 6 mm 2.00 mm 1164 mm
B&B Manufacturing US Belt 3 mm 2.00 mm 54-1910 mm
B&B Manufacturing US Belt 6 mm 2.00 mm 54-1910 mm
B&B Manufacturing US Belt 9 mm 2.00 mm 54-1910 mm
Beltingonline UK Separate Belt at 900mm length 6 mm 2.00 mm 900 mm Genuine Gates/Unitta GT2 belting.
Beltingonline UK Separate Belt at 976mm length 6 mm 2.00 mm 976 mm Genuine Gates/Unitta GT2 belting.
Beltingonline UK Separate Belt at 1032mm length 6 mm 2.00 mm 1032 mm Genuine Gates/Unitta GT2 belting.
Beltingonline UK Separate Belt at 1164mm length 6 mm 2.00 mm 1164 mm Genuine Gates/Unitta GT2 belting.
Beltingonline UK Separate Belt at 1386mm length 6 mm 2.00 mm 1386 mm Genuine Gates/Unitta GT2 belting.
Beltingonline UK Separate Belt at 1524mm length 6 mm 2.00 mm 1524 mm Genuine Gates/Unitta GT2 belting.
Beltingonline UK Universal Kit for RepRap/Other 3D Printers 6 mm 2.00 mm 1032 & 1164 mm Genuine Gates/Unitta GT2 belting & UK Manufactured Pulleys
Beltingonline UK Kit for RepRap Prusa 6 mm 2.00 mm 900 mm Genuine Gates/Unitta GT2 belting & UK Manufactured Pulleys
Beltingonline UK Kit for Rostock Delta Robot 6 mm 2.00 mm 1524 mm Genuine Gates/Unitta GT2 belting & UK Manufactured Pulleys
Beltingonline UK Kit for Rostock Mini 6 mm 2.00 mm 1032 mm Genuine Gates/Unitta GT2 belting & UK Manufactured Pulleys
Charlie's 3D Technologies BE Belt 6 mm 2.03 mm 1000 mm
Cubic-Print DE GT2 Belt kit 6 mm 2.00 mm cut to length
eBay: fabster3d CN Belt 6 mm   974-1164 mm
eBay: yellowvirtualsales US Precision GT2 Belt 6 mm 2.00 mm Cut To Length
EmotionTech FR Belt 6 mm 2.00 mm 850 mm
Fabberworld CH Belt 6 mm 2.00 mm 1000+ mm
Gadgets 3D PL Kit for RepRap Prusa 2 6 mm   976 mm x 3
Gadgets 3D PL Kit for Rostock Mini 6 mm   900 mm x 3
Makemendel IN GT2 Belt 7 mm 2.00 mm 660 mm
Misumi US 2GT Belt 4 mm 2.00 mm 662-9942 mm
Misumi US 2GT Belt 6 mm 2.00 mm 662-9942 mm
Misumi US 2GT Belt 9 mm 2.00 mm 662-9942 mm
ReprapWorld.com EU [1] 6 mm 2.00 mm 1000-75000 mm
RobotDigg CN 202mm Closed-loop GT2 Belt 6 mm 2.00 mm 202 mm
RobotDigg CN 760mm Closed-loop GT2 Belt 6 mm 2.00 mm 760 mm
RobotDigg CN GT2 Belt Open Ended 6 mm 2.00 mm 1000-50000 mm
RobotDigg CN MXL Belt 6 mm 2.00 mm 1000-50000 mm
RoyalSupply US Belt 6 mm 2.00 mm 1164 mm
TechPaladin Printing US Belt 6 mm 2.00 mm 1380 mm
Thingibox ES GT2 Belt 5 mm 2.00 mm any Worldwide shipping
Ultibots US Belt 6 mm 2.00 mm 1164 mm
There is also some on ebay.
  • beside GT2 belts, there is also 2M that have a 2mm round pitch (like [2] and many other suppliers)
Pulleys
See also GT2 Timing Belt.
Supplier From Type available Pitch Tooth Size (bore, OD,...) Max belt width Material Additional notes
3DCracker CN GT2 2 mm 16, 20, 36 5 mm or 8mm 7 mm All Aluminum -
3DMakerWorld US GT2 2 mm 36 5 mm 6 mm Polycarbonate, fiberglass reinforced, brass insert -
Charlie's 3D Technologies Belgium MXL and GT2 - 15 or 20 - - - -
T5
2.5mm
5 mm
8, 16 5 mm 7 mm alu + steel grub screws -
BBMan US many
Belting Online UK GT2, T2.5, T5 & MXL 2mm, 2.5mm, 2.03mm & 5mm 16, 18, 20, 36
Also Special Made to order if required
5mm
Specials sizes are possible.
6mm Alu + Grub Screws Quality Pulleys Manufactured in the UK.
Econobelt US many
eBay: Yellowvirtualsales USA GT2, HDT3M 2MM / 3MM 12-36 5 mm 6-10MM mm Fiberglass Reinforced Fast Worldwide Shipping
Inventables US MXL - - - - - -
MakeMendel India T2.5 2,5 mm 16 5 mm  ? Alu -
Misumi multiple
Paoparts France T2,5
T5
RepRapWorld Netherlands T5 5 mm 8 5 mm x 17 mm x 20 mm  ? Alu Pulley profile has play resulting in lash when reversing
RobotDigg China GT2, T2.5 and MXL 2mm, 2.5mm, 2.03mm 16, 18, 20, 36 5*17.5*18 mm 7mm Alu SKYPE: robotdigg
Royal Supply US GT2 2 mm 18 4,7 mm 6 mm Alu you'll need to redrill the bore (3/16") to fit usual 5 mm motor shaft
SDP-SI US many
TechPaladin US GT2 2 mm 36 5 mm 6 mm plastic/bronze -
Thingibox Spain GT2 2 mm 16 5 mm 4-6 mm Aluminium + grub screws Worldwide shipping
Ultimachine US GT2 2 mm 20 5 mm 6 mm Alu use two set screws
Vendor Loc. Product Material Belt width Bore Tooth Flange Additional notes
3D Acessories Hub IN GT2 Pulley Aluminium 7 mm 5.00 mm 20 -
3DCracker CN GT2 Pulley   7 mm 5, 8mm 16, 20, 36 double
eBay: Yellowvirtualsales US Timing Pulleys Aluminum, Metal 6mm - 10mm 5.00 mm 12-36 Vary
3Distributed UK Pulley   7 mm 5.00 mm 20 double
3Distributed UK Prusa Kit   7 mm 5.00 mm 20 double
3Distributed UK Rostock/Delta Kit   7 mm 5.00 mm 20 double
3DMakerWorld US Pulley Polycarbonate, fiberglass, brass 6 mm 5.00 mm 36 double
B&B Manufacturing US Pulley Aluminium 3 mm 5.00 mm 12-20 double
B&B Manufacturing US Pulley Aluminium 6 mm 5.00 mm 12-20 double
B&B Manufacturing US Pulley Aluminium 9 mm 5.00 mm 12-20 double
Beltingonline UK Separate Timing Pulley (sold each) Aluminium 6 mm 5.00 mm 20 double UK Manufactured Precision Pulley
Beltingonline UK Universal Kit for RepRap/Other 3D Printers Aluminium   5.00 mm 20 double Genuine Gates/Unitta GT2 belting & UK Manufactured Pulleys
Beltingonline UK Kit for RepRap Prusa Aluminium   5.00 mm 20 double Genuine Gates/Unitta GT2 belting & UK Manufactured Pulleys
Beltingonline UK Kit for Rostock Delta Robot Aluminium   5.00 mm 20 double Genuine Gates/Unitta GT2 belting & UK Manufactured Pulleys
Beltingonline UK Kit for Rostock Mini Aluminium   5.00 mm 20 double Genuine Gates/Unitta GT2 belting & UK Manufactured Pulleys
Charlie's 3D Technologies BE Pulley Aluminium, nylon 7 mm 5.00 mm 20 double
Charlie's 3D Technologies BE Pulley Aluminium 7 mm 5.00 mm 20 double
Cubic-Print DE Pulley / Kit Aluminium 7 mm 5.00 mm 20 double
eBay: fabster3d CN Pulley Aluminium (black) 7 mm 5.00 mm 20 double
EmotionTech FR Pulley Aluminium 6 mm 5.00 mm 20 double
Fabberworld CH Pulley Aluminium 6 mm 5.00 mm 20 double
Gadgets 3D PL Kit for RepRap Prusa 2 Aluminium (black) 6 mm 5.00 mm 20 double
Gadgets 3D PL Kit for Rostock Mini Aluminium (black) 6 mm 5.00 mm 20 double
Makemendel IN GT2 Pulley Aluminium 7 mm 5.00 mm 20 -
Misumi US 2GT Pulley Aluminium 4 mm 5.00 mm 32 double
Misumi US 2GT Pulley Aluminium 6 mm 5.00 mm 32 double
Misumi US 2GT Pulley Aluminium 9 mm 5.00 mm 32 double
ReprapWorld.com EU Multiple types of Pulley Aluminium 5-6 mm 5mm Multiple double
Robotdigg CN 16Teeth 2GT Pulley Aluminium 7 mm 5mm, 8mm 16 double
Robotdigg CN GT2 Pulley Aluminium 7 mm 5mm, 8mm 20 double
Robotdigg CN GT2 Pulley Aluminium 7 mm 5mm 36 double
RoyalSupply US Pulley Aluminium 4-6 mm 4.76 mm 18 double You'll need to redrill them to fit on the usual 5mm motor shaft
Stock Drive Products US Pulley     5.00 mm 36
Stock Drive Products US Pulley     5.00 mm 40
Stock Drive Products US Pulley     5.00 mm 42
TechPaladin Printing US Pulley Aluminium 6 mm 5.00 mm 20 double
Thingibox ES GT2 Pulley Aluminium 4-6 mm 5.00 mm 16 double Length: 7mm; Worldwide shipping
Ultibots US Pulley Aluminium 6 mm 5.00 mm 20 double
UltiMachine US Pulley Aluminium 6 mm 5.00 mm 20 double
Stock Drive Products US https://sdp-si.com/  ?  ?  ?  ?  ? In the US, a popular source is SDP/SI. They sell a huge variety of belts and pulleys that meet our needs. Always call SDP/SI for stock, their website is always out of date.
  • Pulleys (bad link)
    Filter for GT2, 2mm pitch, then choose the bore size needed for your steppers.
  • Belts (bad link)
    Filter on GT2, 2mm Pitch, and get 2 belts as close to 1m long as possible.
Note, unfortunately, SDP/SI does not carry a smaller diameter GT2 pulley with a 5mm bore, so to buy your pulleys here you need a larger pulley than in strictly ideal. These are fine, though. I (Virtlink ?) use the 36 tooth pulleys on my printer and they work great.
Misumi Japan Misumi's pulley introduction  ?  ?  ?  ?  ?
Another good source for GT2 pulleys and belts is Misumi. They carry a huge variety of suitable pulleys, including several that are closer to out ideal diameter. In addition, Misumi has offices around the globe so they are a better choice for international customers (though some regions will only sell to businesses).
Their website does not make it easy to browse for belts and pulleys, but here are the relevent pages in their catalog:
Note: Misumi calls theirs 2GT (2mm pitch) and 3GT (3mm pitch). As far as I know they are compatible with GT2, but both offer the same benefits. Misumi's pulleys seem expensive, but they are metal pulleys. We don't really need metal pulleys for our needs, but they are fine.
RobotDigg
China manufacturer base MXL pulley, GT2 pulley supplier. MXL belt and GT2 belt in different width, open ended or closed-loop. MXL pulley 18 teeth 5mm bore and mxl belt from stock for quick response. GT2 pulley 20 teeth 5mm bore and 8mm bore from stock. GT2 pulley 36 teeth 5mm bore from stock, can be redrill to 6.35mm or 8mm bore to fix.
  • MXL
    MXL pulley 18 teeth, 5mm bore
  • 2GT
    GT2 pulley 20 teeth, 5mm bore
  • 2GT
    GT2 pulley 20 teeth, 8mm bore
  • 2GT
    GT2 pulley 36 teeth, 8mm bore
More pulleys available. OEM service for small quantity a 100pcs base.
Cable
