Belts and Pulleys
This page has been flagged as containing duplicate material that GT2_Timing_Belt also attempts to cover.
These pages should be merged such that both pages do not attempt to cover the duplicate topics.
See also Choosing_Belts_and_Pulleys
Belts
Supplier | From | Type available | Pitch | Width | Length | Material | Additional notes |
3DCracker | CN | GT2 | 2 mm | 6 mm | 1350mm and open ended | Neoprene, fiberglass reinforced | - |
3DMakerWorld | US | GT2 | 2 mm | 6 mm | 1164 mm | Neoprene, fiberglass reinforced | - |
Charlie's 3D Technologies | Belgium | MXL and GT2 | - | - | - | - | - |
Cubic Print | Germany | T2.5 T5 |
2.5 mm 5 mm |
6 mm | as you wish | PU + steel | open belts |
BBMan | US | Imperial/Metric | |||||
Belting Online | UK | GT2, MXL, T2.5, T5 | 2 mm 2.5 & 5mm | As you wish | As you wish | PU & Neoprene Rubber | Genuine Branded Quality Products |
eBay: Yellowvirtualsales | USA | Precision GT2 | 2 mm | 6 mm | Cut To Length | Fiberglass Reinforced | Fast Worldwide Shipping |
Econobelt | US | many | |||||
Eke | China | many | |||||
Indiamart | India | many | |||||
Inventables | US | MXL | - | - | 1 foot increments | - | - |
KainaBelt | China | many | |||||
Makemendel | India | T2.5 | 2,5 mm | 7 mm | 700 mm | - | - |
Megadyne | Italy | many | |||||
Misumi | multiple | ||||||
Paoparts | France | T2.5 T5 |
2,5mm 5mm |
5mm | - | PU | |
PolyBelt | US | T2.5 T5 |
5 mm | 6 mm | - | polyurethane + steel | - |
RepRapWorld | Netherlands | T2.5 T5 |
2,5 mm 5 mm |
5 mm 5 mm |
1 m | neoprene polyurethane + steel |
RobotDigg | China | GT2, MXL, T2.5 | 2 mm | 6mm, 6.35mm or 9mm | 20M or 50M per roll ,Closed-loop GT2 | Neoprene Rubber, Fiberglass Reinforced. MOQ 50M | |
Royal supply | US | GT2 | 2 mm | 6 mm | 1164 mm | fiberglass / nylon / neoprene | - |
SDP-SI | US | Imperial/Metric | |||||
TechPaladin | US | GT2 | 2 mm | 5 mm | 1160 mm | neoprene | - |
Tanals | France | many | - | - | - | - | don't sell to individuals |
Thingibox | Spain | GT2 | 2mm | 5 mm | 1 m | Neoprene Rubber | Worldwide shipping |
There is also some on ebay.
- beside GT2 belts, there is also 2M that have a 2mm round pitch (like [1] and many other suppliers)
Pulleys
Supplier | From | Type available | Pitch | Tooth | Size (bore, OD,...) | Max belt width | Material | Additional notes |
3DMakerWorld | US | GT2 | 2 mm | 36 | 5 mm | 6 mm | Polycarbonate, fiberglass reinforced, brass insert | - |
Charlie's 3D Technologies | Belgium | MXL and GT2 | - | 15 or 20 | - | - | - | - |
2.5mm 5 mm |
8, 16 | 5 mm | 7 mm | alu + steel grub screws | - |
BBMan | US | many | ||||||
Belting Online | UK | GT2, T2.5, T5 & MXL | 2mm, 2.5mm, 2.03mm & 5mm | 16, 18, 20, 36 Also Special Made to order if required |
5mm Specials sizes are possible. |
6mm | Alu + Grub Screws | Quality Pulleys Manufactured in the UK. |
Econobelt | US | many | ||||||
eBay: Yellowvirtualsales | USA | GT2, HDT3M | 2MM / 3MM | 12-36 | 5 mm | 6-10MM mm | Fiberglass Reinforced | Fast Worldwide Shipping |
Inventables | US | MXL | - | - | - | - | - | - |
MakeMendel | India | T2.5 | 2,5 mm | 16 | 5 mm | ? | Alu | - |
Misumi | multiple | |||||||
Paoparts | France | T2,5 T5 | ||||||
RepRapWorld | Netherlands | T5 | 5 mm | 8 | 5 mm x 17 mm x 20 mm | ? | Alu | Pulley profile has play resulting in lash when reversing |
RobotDigg | China | GT2, T2.5 and MXL | 2mm, 2.5mm, 2.03mm | 16, 18, 20, 36 | 5*17.5*18 mm | 7mm | Alu | SKYPE: robotdigg |
Royal Supply | US | GT2 | 2 mm | 18 | 4,7 mm | 6 mm | Alu | you'll need to redrill the bore (3/16") to fit usual 5 mm motor shaft |
SDP-SI | US | many | ||||||
TechPaladin | US | GT2 | 2 mm | 36 | 5 mm | 6 mm | plastic/bronze | - |
Thingibox | Spain | GT2 | 2 mm | 16 | 5 mm | 4-6 mm | Aluminium + grub screws | Worldwide shipping |
Ultimachine | US | GT2 | 2 mm | 20 | 5 mm | 6 mm | Alu | use two set screws |
