Balancing ATX Supplies
Revision as of 20:32, 3 December 2011 by Bryanandaimee (talk | contribs)
A modern high power ATX supply off a PC is a good way to power your RepRap but requires a bit more care than a purpose built 12V supply. The main issue with these supplies is the requirement for a load on the 5V line. To get reliable opperation you will need to balance the loads on the 12V vs the 5V lines.
12 V Load 5 V Load 12 V Voltage 5 V Voltage
12 pla-bushing RP-PLA check your build file, the file makes either 4 or 12 Pm-bushings.jpg
