Balancing ATX Supplies
Revision as of 20:23, 3 December 2011 by Bryanandaimee (talk | contribs) (Created page with 'A modern high power ATX supply off a PC is a good way to power your RepRap but requires a bit more care than a purpose built 12V supply. The main issue with these supplies is the…')
A modern high power ATX supply off a PC is a good way to power your RepRap but requires a bit more care than a purpose built 12V supply. The main issue with these supplies is the requirement for a load on the 5V line. To get reliable opperation you will need to balance the loads on the 12V vs the 5V lines.
