Azteeg X1
Work in Progress
Introduction
The Azteeg X1 3DP is an open source controller designed to be used in RepRap 3D Printers and similar cartesian based machines including CNCs. It has all the features needed to run all current and future single extruder designs.
The X1 is based on Sanguino/Sanguinololu and is compatible with most Arduino based firmware(Sprinter, Marlin, Repetier, plus others.). It is pin to pin compatible with the Sanguinololu with the addition of a FAN PIN. The X1 features mostly SMT parts to ease production and reduce cost.
Compatible with Pololu and Stepstick stepper motor drivers with the ability to use an external power source for the motors with higher voltages.
The Azteeg X1 3DP is your low cost, compact and expandable 3DP printer controller. Fully Assembled except for the white connectors where you have a choice between right angle and vertical orientation. Soldering iron required.
Features
- Atmel ATMEGA 644P with FT232RL FTDI USB chip
- Compatible with Sprinter, Marlin, Repetier, others.
- Mosfet control for 1 extruder and 1 hotbed
- Extra PWM control for small fan or LEDs
- 3 end stops and 2 thermistor inputs
- 12-30v input high efficiency switching Power supply @ 500ma max
- Dedicated uSD card female header [SDRAMPS compatible]
- Low RDSon Mosfets for less heat buildup
- Input power selector for micro controller [USB or internal regulator]
- Secondary power input for stepper motors.
- Optional pads for TVS spike suppression diodes for the Mosfets
- Mosfet Heatsinks included
- i2C, Tx1 serial, +5, GND, SPI and ADC pins on the expansion ports
- Fast acting blade fuse
- Both right angle and vertical connector sets included
- Lots of LEDs, Rx/TX serial, PWR, hot end and hot bed.
Images
Product Photos
Final version may differ slightly from shown.
User Photos and videos
<videoflash type="youtube">7gV8H0dhAhI|480|360</videoflash>
Early Prototypes
Files and Documentation
Schematics: http://files.panucatt.com/datasheets/azteeg_x1_schematics.pdf
Wiring Diagram: http://files.panucatt.com/datasheets/azteeg_x1_wiring.pdf
Test code (for Azteeg X1 and Sanguinololu 1.3): http://reprap.org/wiki/File:AzteegX1_Sang_testcode.zip
Getting Started Guide
Hardware
Tools required: Soldering Iron, Solder, Phillips Screw Driver.
1. Solder Connectors - The Kit comes with right angle and vertical connectors so you can choose which configuration is best for your installation. 0.1" pitch terminal blocks can also be used as shown above(Emmanuel's install).Inspect the solder joints after soldering to ensure a good and reliable connection, a loose pin or connector will be difficult to troubleshoot later.
2. Install Heatsinks - Use hardware supplied to fasten the heatsink, Thermal grease is provided but not required for normal operation. Straighten the heatsink before tightening the screws and check that both heatsinks are not touching each other. Use a long nose pliers to secure the heatsink while tightening.
3. Insert jumpers for step size - Consult your stepper drivers documentation to determine your step size settings. See wiring diagram for location and designations of the stepper pins. Push the jumpers all the way down to ensure good contact.
4. Solder TVS Spike supression diodes[optional] - These diodes help clamp down voltage spikes during on-off switching of the Mosfets. It is not required for normal operation but is highly recomended for stability of the board. The pads(SMB) for these are located at the bottom of the PCB near the Mosfet pins, they can be sodered in any orientation as they are non-polarized, bi-directional versions.
5. Solder SDRAMPS/uSD Carrier header[optional] - Solder the 2x4 female header on the pads right side of the thermistor connectors(First few units shipped with a female header with pins that are a tad fatter and need a little nudge to put in).
6. Install Stepper Drivers - The Azteeg X1 is compatible with the Pololu style A4983/88, stepstick and other similar drivers. Please see the wiring diagram for pin designations and driver orientation. Incorrect Placement will damage the board and drivers.
7. Wire it up - Use the wiring diagram as a guide to connect power, the heatbed, hotend and the rest of the connectors. Check and double check polarity as you go about. When inserting wire to the terminal block, make sure there are no stray wire strands to create shorts. Crimp the wires and give it a slight pull after inserting into the mating connectors to check that it is locked in(push crimp pins into the housing with a small screw driver if it does not lock in). Use appropriately sized wires, #18-20 for Motors, #22-26 for Endstops and Thermistors. #12-14 for Main supply, #12-14 for Heatbed, #14-16 for the Hotend and keep high current carrying wires as short as possible. Secure all mating connectors all the way into the headers. Tighten terminal block screws.
8. Using secondary power input[optional] - If you need/want to supply your motors with a higher voltage you can use the input connector as shown in the picture. Ensure that your secondary power supply has enough capacity to run the motors. If not using a secondary supply and with the Ext Vmot Jumper installed, the secondary input connector will have 12v(always on) and can be used to power 12v fans or LED strings.
9. Last check before power up
- EXT Vmot Jumper is installed (except when using a secondary power supply)
- Input Select Jumper is in INT position(recommended) or in USB(for testing)
- Reset jumper in place(remove only after programming or uploading firmware, having this connected when connecting the USB will reset the controller)
- Stepper Drivers are correctly oriented
- Check all wiring polarity
- Check for loose crimp pins
- Heat sinks are secure and does not touch each other or any conductive part of the board
- All screws of the terminal block are tightened
- Fuse is installed(20amps when using a heated bed and 5Amps when not)
Software
Tools required: - Arduino IDE ver 0022/0023, Firmware, Mini-USB cable, FTDI USB VCP drivers(optional)
Bootloader - A bootloader is a piece of code that resides in the controller, it allows you to upload firmware via USB and without using a dedicated programmer like the AVRISP MKII. The Azteeg X1 comes pre-loaded with an Arduino compatible(sanguino) Bootloader for the Atmega644P chip. To re-burn the bootloader you would need an ICSP programmer like the AVRISP MKII, USBtiny, and other compatible devices.
Firmware - Like the Sanguino, Sanguinololu and other controllers based on the Atmega644P, the X1 needs a patch to run on the Arduino IDE. You can get this from the Sanguino project home and is also included in the Marlin firmware download which you can get at ErikZalm's Github. The X1 is compatible with most Arduino based firmware and tested with Sprinter, Marlin, Repetier-Firmware
- Let's start off by getting the 0023 Arduino IDE, our Sanguino Patch, also Marlin firmwareor Sprinter firmware.
- Extract Arduino IDE into a folder in your hard drive, extract the Sanguino download which is a folder named "Sanguino". Copy this "Sanguino" Folder and paste it in your Arduino "Hardware" folder. This Hardware folder will now contain the following folders after pasting "Arduino", "Sanguino" and "Tools"( if you dont see those, you must have placed it on the wrong folder).
- Double click on the Arduino.exe to run the the Arduino IDE, click Tools --> Board then select Sanguino w/ 644P(on older sanguino patches it would only show Sanguino).You are now ready to either burn a new bootloader(using a ICSP programmer) or upload firmware via USB.
Where to get it
Pre-order at the For Sale forum. http://forums.reprap.org/read.php?94,122236
