Arduino Mega Pololu Shield
Revision as of 12:17, 13 August 2010 by Johnnyr (talk | contribs) (removed heated bed claim)
Release status: Experimental
A circuit board that fits on the Arduino MEGA and holds Pololu A4983 stepper driver carrier and the rest of RepRap's electronics.
Electronics
Summary
This board is mostly based on Adrian's Pololu_Electronics and work by Tonok. It is designed to fit the entire electronics needed for a RepRap in one small package for low cost. It has provisions for the cartesian robot and extruder. And is expandable to control other accessories. It fits 4 Pololu A4983 stepper drivers, 3 mosfets for heater / fan outputs and 2 thermistor circuits.
RepRap Arduino Mega Pololu Shield wired to Mendel. Everything soldered. The printed bottom of the board. Crude attempt at printing labels. This is an angle view of the shield.
A couple features that stand out are placing the Pololu boards on pin header sockets so they can be replaced easily or removed for use in future designs. Placing the Pololus up as another layer allows us to put the capacitors and pull up resistors for each stepper driver underneath it. The pin headers for the stepper motor outputs are placed on top of the Pololu boards saving routing them on the main shield.
The X and Z endstops are on interrupt pins. I2C and SPI pins left available for future expansion. All the Mosfets are hooked into PWM pins for versatility.
Servo style connectors are used to connect to the endstops, motors, and leds. These connectors are gold plated, rated for 3A, and very compact.
Assembly Instructions
Component Soldering
Use your preferred circuit board manufacturing method. :) If you are doing point to point wiring make sure to read that section first
  1. Place the connectors shown below to make sure the top wires do not interfere with their future placement. You can insert strips of pin headers into the female connectors to keep them aligned while soldering.
  2. Solder the top wires.
  3. Solder the resistors as shown to the right.
  4. Solder the capacitors as shown lower right. They must be inserted in the correct orientation. + to the top or left. Place the caps and bend their leads so that they are in the desired position (without leads shorted) before soldering.
  5. Solder the rest of the components. Mosfets must be oriented correctly. It is usually easiest to place components in order from shortest to tallest. Save the stackable headers for last. The diode is optional if you are powering the Arduino from the shields 12V input(if used it must be in the show orientation. If higher that 12V is used to power the shield the diode should be omitted to prevent damage.***Warning:Only tested at 12V***
  6. Thoroughly check for shorts. Check for continuity between all pins and GND,12V, 5V, and any pins next to them.
Point to point wiring with proto shield
Make sure to check the prototype shield you use for pin holes that have traces tying them together. You most likely will have to cut some traces to keep from shorting circuits together that do not belong. The board used here is the Arduino Mega shield one manufactured by Arduino. I only had to cut traces in about 4 places and it only took a couple seconds each with the little grinding bit on a dremel tool. Pictured below are the traces that need cut on the Tinker-It shield, both traces need cut in the small red circle, the top trace cut twice in the big circle to isolate the pins there.
If wiring a shield make sure to leave the area above the usb jack and ISCP header clear of components or the board is spaced / electrically insulated sufficiently to avoid shorts to the Arduino Mega board components.
This is the front of the shield. The traces that need cut on the Tinker-It shield.
This is the schematic of the shield.
Warnings:
The endstop pins are Signal - VCC - GND, instead of the VCC - Sig - GND like the rest of RepRaps boards. Make sure to wire them correctly. This is done to allow squeezing fatter traces on the printable board.
Ingredients
Source
Eagle_Library
File:ArduinoMegaPololuShield.zip
copper etch resists methods suggested by Vik circuit design based mostly on Adrian's Pololu_Electronics Used Joaz's pin definitions for initial layout
Bill of Materials
ID Description Quantity Part Number
U1 Arduino Mega 1
U2,U3,U4,U5 Pololu A4983 carrier 4
C1,C2,C3,C9 100uF capacitor 4
C5,C8 10uF capacitor 2
R1,R7 4.7K resistor 2
R2,R4,R9 100K resistor 3
R3,R5,R6,R8 47K resistor 4
Q1,Q2,Q3 N-channel Mosfet 3 STP55NF06L
D1 Diode 1 1N4004
F1 PTC resettable fuse 1 MF-R500
J1 Power Jack 1 RAPC712X
J2 5.08 Eurostyle screw terminal 1 282837-6
LED1 5mm Green LED 1
S1 Push button switch 1 FSMRACD
20 pin header 1 (extras for additional pins)
10 pin header 1
2 x 18 Pin Stackable Female Header 1
8 Pin Stackable Female Header 5
6 Pin Stackable Female Header 1
16 Pin Female Header 4
Circuit Board 1
Firmware and New Pin Assignments:
You will need the Arduino software at http://www.arduino.cc/en/Main/Software to upload the firmware to Arduino Mega.
Here are the pin definitions for this board. The following values need to be entered to "Arduino Mega pin assignment" in the "pins.h" file of the firmware.
NEW AS OF 29 July 2010
#define X_STEP_PIN         26
#define X_DIR_PIN          28
#define X_ENABLE_PIN       24
#define X_MIN_PIN           3
#define X_MAX_PIN           2
#define Y_STEP_PIN         38
#define Y_DIR_PIN          40
#define Y_ENABLE_PIN       36
#define Y_MIN_PIN          16
#define Y_MAX_PIN          17
#define Z_STEP_PIN         44
#define Z_DIR_PIN          46
#define Z_ENABLE_PIN       42
#define Z_MIN_PIN          18
#define Z_MAX_PIN          19
#define E_STEP_PIN         32
#define E_DIR_PIN          34
#define E_ENABLE_PIN       30
#define LED_PIN            13
#define FAN_PIN            -1
#define PS_ON_PIN          -1
#define KILL_PIN           -1
#define HEATER_0_PIN        12
#define TEMP_0_PIN          2   // MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!!
Wish list
This shield would like to replicate with the following external boards
  1. Additional Stepper Driver
  2. DC Driver
  3. Thermistor
  4. Thermocouple
  5. SD Card
  6. Control Panel w/LCD
  7. Ethernet
  8. Host USB
This is the back of the shield.
