Arduino Mega
Revision as of 06:59, 8 August 2010 by Capo (talk | contribs) (Created page with 'Quoting verbatim from the Arduino websitehttp://arduino.cc/en/Main/ArduinoBoardMega ''"The Arduino Mega is a microcontroller board based on the ATmega1280 (datasheet). It h…')
Quoting verbatim from the Arduino website[[1]]
"The Arduino Mega is a microcontroller board based on the ATmega1280 (datasheet). It has 54 digital input/output pins (of which 14 can be used as PWM outputs), 16 analog inputs, 4 UARTs (hardware serial ports), a 16 MHz crystal oscillator, a USB connection, a power jack, an ICSP header, and a reset button. It contains everything needed to support the microcontroller; simply connect it to a computer with a USB cable or power it with a AC-to-DC adapter or battery to get started. The Mega is compatible with most shields designed for the Arduino Duemilanove or Diecimila."
Specifications
This is 400 pixels wide, and on the left.
Summary
  • Microcontroller: ATmega1280
  • Operating Voltage: 5V
  • Input Voltage (recommended): 7-12V
  • Input Voltage (limits): 6-20V
  • Digital I/O Pins: 54 (of which 14 provide PWM output)
  • Analog Input Pins: 16
  • DC Current per I/O Pin: 40 mA
  • DC Current for 3.3V Pin: 50 mA
  • Flash Memory: 128 KB of which 4 KB used by bootloader
  • SRAM :8 KB
  • EEPROM :4 KB
  • Clock Speed: 16 MHz
Offical support
http://www.arduino.cc/en/Main/Software http://arduino.cc/en/Guide/HomePage
Related Projects
