A list of common problems
Revision as of 07:22, 28 January 2014 by Gregor (talk | contribs)
Here you find a list of common problems which can occur during the print.
Object bend up from the heatbead (ABS)
I had this problem under the following environment:
  • printer: reprap prusa i3
  • extrude: mgs
  • nozzle: jhead 0.5mm
  • filament: abs black 3mm
How it looks during fail:
Solution 1
after many try an errors i found the following solution:
my printer said it has 100°C on the heat bed but it were only 80°C. i had to replace the thermistor. after this i the abs sticks much better. i set the temperature to 105°C because more heat need a very long time to heat up. it is very important to calibrate the levelling correct and adjust the nozzle-heat bed distance.
Layers broken (ABS)
  • extrude: mgs
Solution 1
TODO. possible reason: the heat bed turned off during the print.
