A list of common problems
Revision as of 16:27, 27 January 2014 by Gregor (talk | contribs)
Here you find a list of common problems which can occur during the print.
Object bend up from the heatbead (ABS)
I had this problem under the following environment:
  • printer: reprap prusa i3
  • extrude: mgs
  • nozzle: jhead 0.5mm
  • filament: abs black 3mm
How it looks during fail:
Solution 1
after many try an errors i found the following solution:
  • my printer said it has 100°C on the heatbed but it were only 80°C. i had to replace the termistor. after this i the abs sticks much better. i set the temperatur to 105°C because more heat need a very long time to heat up. it is very important to calibrate the leveling correct and adjust the nozzle-heatbed distance.
