ABS HDPE blend
It has been observed independently by User:Bogdan.kecman and User:nophead that ABS and HDPE appear to be miscible. This becomes apparent when switching from coloured ABS to HDPE (or vice versa) in the same extruder. As the first plastic is flushed out by the second you get a filament that slowly changes colour and physical properties from one to the other. The plastic appears to be well mixed in the extruded filament and cannot be separated.
This raises an interesting possibility. ABS and HDPE can both be extruded at the same temperature, i.e. 220-240C. It should be possible to build an extruder with two feeds but a single heater and nozzle. The ratio of the two plastics could then be varied dynamically throughout the building of an object.
HDPE is a very good bearing material, being tough and very slippery, but it doesn't stick to anything other than itself, other forms of PE and PP. Large objects also tend to warp. It may be possible to make the base of an object with 100% ABS, so that it sticks to the bed, and then graduate to 100% HDPE to make bearing surfaces. An ideal application of this would be the Prusa_Mendel X-carriage that has a large flat base and four bushings that need to be slippery and hard wearing.
--Nophead 14:24, 15 January 2011 (UTC)
