ABS
Revision as of 22:04, 28 May 2010 by GregFrost (talk | contribs) (ABS (Acrylonitrile Butadiene Styrene))
A very nice thermoplastic that is stronger, more durable, and more resistant than HDPE. Its a bit pricier, but it has better mechanical properties than plastics such as HDPE.
  • ABS is good because it is easier to buy and easier {Easier in what way? Can someone provide details?} to extrude well for small parts, compared to PLA
Fumes
ABS creates mild, tolerable fumes while being extruded. These fumes, while usually tolerable, may be dangerous for people (or pet birds) with chemical sensitivities or breathing difficulties.
This is caused by the following combustion byproducts:
???? - --Sebastien Bailard 21:55, 27 April 2010 (UTC)
Heater Settings
Extrusion width
There has been some evidence that pigment may affect extrusion width.
If you are switching plastics a lot, it is a good idea to measure the
extrusion before going through the toolpath process.
???True for ABS ??? --Sebastien Bailard 22:02, 27 April 2010 (UTC)
Build Surface and Warping
ABS is bad because it tends to warp catastrophically off the build platform when printing large parts. This can be remedied by using a heated build platform (in which case it is just as nice as PLA and easier {easier in what way? can someone provide details?} to print with!)
Suppliers
Check the forums... someone might be able to ship you some for cheap.
USA
Price Supplier
$7.95 / lb
(orders > 10lbs)
$9.50 / lb
(orders < 10lbs)
Call Donna at +1 (330) 854-3010 plasticweldingrod.com and tell them Forrest or Reprap sent you. (5 lb minimum order, delivery on small orders tends to take several weeks, updated 18 February 2009)
UK
Germany
Price Supplier
€19,78 / kg From a German RepRap supplier reprapsource.com
